If you are wondering what having digital microprocessor control can mean, just ask anyone who has used it. The benefits are numerous, whether its increased productivity, or increased weld quality, or the ability to make precise settings, and fine tune them to the exact standards required....
The EV6500ATS generator is an economical emergency power backup system with Automatic transfer for times when power is desparately needed. The unit features a fuel sipping, reliable diesel engine which provides day long operation on a single tank of fuel. This enclosed quiet unit is...
For well over a decade, Everlast has been of the leading edge of the effort to pioneer the rise of reliable and affordable inverter MIG welders. The success that the old i-MIG inverter series enjoyed is a thing of legend. In fact, when we first introduced the...
The all digital Cyclone 200ES is a updated model of the popular Cyclone 200E MIG welder. Don't worry, it still retains all the things of the Cyclone 200E. It's still a good MIG welder with 200A capability, and a 25% duty cycle at 180A. Nothing has changed as far as that goes. However, this...
Equally suitable for both the welding enthusiast and the professional that is in need of a well equipped AC/DC TIG welder, the Everlast PowerTIG 250EX is a versatile solution. Not only is it versatile, it's a true performer, putting out 250 amps of TIG welding power on single phase 240V...
Fits all Everlast Power i-MIG units with a Euro Quick connector
Best suited for Power i-MIG 140E, Cyclone 140E, Power i-MIG 200E, Cyclone 200E, Cyclone 212
Rated at 180 Amp CO2 / 150 Amp mixed gases @ 60% duty cycle
Major torch parts and consumables are interchangeable with Binzel® MB15AK...
SM200N Spool Gun designed to fit Power i-MIG units with Euro-style Connector
Speed control is controlled on the welder and not on the spool gun. Must be limited to 200A or less use
Recommended for older Power i-MIG 200.
200A with 35% Duty Cycle
Euro-style...
This torch is designed for older High Frequency start cut 40 and 50 and SuperCut 50 units without pilot arc capability. Metric thread compression connection.
2 Pin Female style Plug for SM100N and SM3035N Spool Guns or for AG-60 Plasma Torches to be used with SuperCut 50P/51P.
2 Pin FEMALE Plug
2 Internal Pins for full control
Panasonic® design
1/2" (nominal) diameter
For SM100N, SM3035N Spool Guns and AG-60 Plasma...
9/20 GAS LENS TIG KIT
WP 9/20 GAS LENS TIG KIT suitable for the WP9 and WP20 TIG torch
Contents:
5 - Alumina Nozzles 4-5-6-7-8 (1 Each)
2 - 1/16" 2% Ceriated Tungsten
1 - 3/32" 2% Ceriated Tungsten
1 - 1/8" 2% Ceriated Tungsten
2 - 1/16" 2% Lanthanated Tungsten
1...
MIG Contact Tip Kit 0.030" (0.8mm)
M6 thread
For SN-15 and 15 series MIG Guns
Light-Duty design
E-CU (copper)
10 piece kit
Fits AG 60 High Frequency torches/
10 piece electrodes.
Drive Roll for Hard (steel) wire
.023"-.030" (0.6mm-0.8mm)
1 Piece Kit
For use with "2 roll" systems with one (single) drive roll
NOT for units with external Wire Feeder
When it comes to DC TIG welders, you won't find a more feature packed, performance driven machine than the Power i-TIG 200T. It's user-friendly interface is thoughtfully arranged, with an intuitive design that is charachteristic that people have come to expect from Everlast products. ...
A long time standard in the Everlast lineup, the PowerTIG 200 models have been placed in all sorts of demanding conditions since 2009. It's a favorite among light and medium fabricators who want a simple interface, but still want to have upscale features. Undoubtedly, the newest...
Designed for heavy commercial applications, the PowerTIG 315LX is a highly capable, AC/DC TIG and Stick welder with power to spare for most jobs. The IGBT inverter creates a stable smooth arc, and provides a true industrial duty cycle of 60% at 315 amps. This unit operates on 240V...
If you are looking to take your shop or business to the next level in TIG welding capability, the digital inverter-based PowerTIG 255EXT delivers exceptional power and performance at a budget friendly price. In fact, the PowerTIG 255EXT not only has a long list of competitive features...
The PowerTIG 325EXT is built for superior industrial performance. With Digital microprocessor control over the IGBT inverter, and up to 325 amps of TIG welding Power, the PowerTIG 325EXT packs considerable punch. The IGBT module inverter design creates a reliable and serviceable...
As part of the MIG, TIG and Stick line from Everlast, the PowerMTS 400 falls into the CC/CV power source class. This means that the inverter power supply is not incorporated into the wire feeder section. This allows the unit to be used exlusively for one type of operation for...
If you are looking for maximum flexibility and performance in a small utility class welder package, look no further than the PowerARC 140ST from Everlast. This tiny IGBT inverter welder features both Stick and DC Lift TIG capability. It comes with its own carry case and...
The PowerARC 160i STH is a completely new model that succeeds the PowerARC 160STH. This model retains all the functionality of the older model, but does so with a more reliable and compact digital design. The features that made the PowerARC 160STH popular are still there in this new...
The all new PowerARC 200STi is built with the true professional in mind. With 200 amps of DC Stick/Live Lift TIG welding power, the new compact digitally controlled IGBT inverter welder cuts no corners on performance or design. The unit features E6010 welding capability making the...
This 240V PowerCool cooler can be used with any Everlast welder new or old with the triangular shaped power outlet in the rear. This includes the new generation units from Dec 2020. Note: 2009 and some 2010 model use a different outlet shape, but still provide 240V...
The new Digitally controlled PowerProd 256D is the latest multi-process welder unit from Everlast designed to meet the needs of advanced users who want more precision and control of multiple functions for light commercial duties such as portable repair and general maintenance. The welder unit...
The inverter based EV1000i from Everlast produces a clean sine wave which is safe for use with electronic items. This small unit is perfect for camping, tailgating, and any outdoor or recreational use. The low noise rating makes it acceptable for use in most campgrounds with noise...
For the extra go anywhere capability, the Everlast PowerTIG185 DV delivers dual voltage capability that will enable you to operate virtually anywhere a power outlet is present. The digitally controlled IGBT inverter of PowerTIG 185DV delivers a smooth, steady arc, as good as any unit in...
The inverter based EV2200i Electra wave is capable of generating ample power for a campout, picnic, tail gate party or even powering 120V appliances and electronic devices during a power outage. For construction applications, it's an excellent portable choice for getting the power...
As portable generators go, the Everlast EV2800i Electra Wave generator is more than capable of powering you through any emergency outage, camping trip or tail gate party. If your needs are more construction or farm related, with 2800 surge watts and 2600 continuous watts, the EV 2800i...
If you are needing a quiet running solution to your all-purpose generating needs, the EV3500i Electra Wave generator from Everlast might just be the answer. The 3100 surge Watts and 3000 continuous rated Watts EV3500i offers generous "clean power" output for most 120V appliances,...
Straight handle with flex neck design with Ultra flex cable
Air-Cooled
Rated: 200 Amps DC /150 Amp AC @ 60% Duty Cycle
Complete with standard 1/2" 35 series DINSE style connector
2T/4T remote contactor (finger switch) and quick disconnect gas fitting
Includes small consumable...
