What is IGBT Plasma Cutter
FREE SHIPPING ON ALL PLASMA CUTTERS AND WELDERS ONLY IN LOWER 48 STATES
Plasma Cutting Process
Plasma cutting, simply stated, is a process for cutting steel and metal of different sizes and thickness using the plasma torch. During plasma cutting, the inert gas or compress air used in some machines is ejected at high speed from the nozzle and simultaneously an electrical arc is made from the gas of nozzle to the surface to facilitate the cutting.
This plasma is adequately hot to melt the metal that is cut and it also moves fast to blow the metal far from the present cut. Additionally plasma arc cutters and several other applications also deploy the Insulated Gate Bipolar Transistor (IGBT) plasma cutting technology to provide more commercial plasma cutting equipment.
How IGBT Plasma Cutters Works?
The IGBT plasma cutters adopt a different method to start the pilot arc and are better suited for professional environments. Many IGBT plasma metal cutters often deploy high frequency starting technology, high voltage circuit just for the starting process while others use Pilot Arc starting technology, where the torch enables a constant arc without touching the work piece.
The Insulated Gate Bipolar Transistor (IGBT) versus the Metal Oxide Semi-conductor Field Effect Transistor (MOSFET) has been a controversial subject ever since the IGBT technology came into being in the 1980's.
While developing light weight inverter based welders that consume less power, there are many technologies. Transistors are foundational to creating the welding arc by serving as tiny micro switches that deliver the power to the work electrode. Enormous technical information is available on the use and selection of these transistors and the suitability of each to different application.
IGBT technology for welding applications has certainly proved to more effectively handle the rigorous demands the high duty cycles welders as it offers higher voltage capacities and heat tolerances than the earlier MOSFET.
IGBT Plasma Cutting Technology
It is a fact that MOSFETs are not ideally suited to handle the extreme heat and voltage pressure mounted on them by the industrial welding environment. While MOSFET is certainly sufficient when powering lower end welding equipment, they are not able to measure up when meeting the demands of heavy duty welding requirements.
Of course, MOSFET technology is still available in a limited way in the welder manufacturer's list of products. This is to offer customers an economical alternative particularly for hobbyists and other enthusiasts. Most manufacturers cater to the needs of the professional welder and the welding industry in general by offering an all new line of IGBT based welding inverters.
It has to be admitted that for certain low-end welding applications, MOSFET technology has failed unable to cope up when pushed to limits. IGBT technology, on the other hand, has proved extremely capable of handling all types of work, however tough.
The transistors that were commonly used earlier were MOSFET but today things have changed and IGBT plasma cutters are the ones favored in commercial and industrial applications where the demand of the size of the amperage is high. The IGBT plasma cutter can be commonly found in several high current plasma metal cutting machines that put out more than 60amps of power.
There are several IGBT plasma cutters and welders lined up in the market and most of them are of high quality, easily portable, competitively priced and widely bought by professional welding operators.
