Laser Cleaners
RedSabre 201CP Heavy-Duty PULSE Laser Cleaner
  • Optical Pump: JPT
  • 200W Output
  • Pulsed Fiber Laser Cleaning
  • Air-Cooled
  • Up to 2500Khz pulse
  • Multiple Scan Pattern Shapes for improved cleaning on shaped and irregular surfaces
  • Impact resistant plastic "suitcase" design
  • Portable Touch Screen
  • Compact, table top size
  • Handheld Scanning Gun
  • 240V input
  • 5m (16 ft.) fiber cable
  • Scan Range up to 200mm (7.9") wide
$14,499.00You Save - $2,000.00
$12,499.00 Buy Now
RedSabre 200CP PULSE Laser Cleaner
  • Optical Pump: JPT
  • 200W Output
  • Air-Cooled
  • Steel case design
  • Portable Touch screen
  • 240V input
$13,049.00You Save - $1,050.00
$11,999.00 Buy Now
RedSabre 300CP PULSE Laser Cleaner
  • Optical Pump: JPT
  • 300W Output
  • Air-Cooled
  • Pulsing up to 2500 kHz
  • Steel case design
  • Hand Held Scanning Gun
  • 240V input
  • Scan Range up to 200mm (7.9") wide, depending upon focus lens
$13,099.00You Save - $100.00
$12,999.00 Buy Now
RedSabre 301CP Heavy-Duty PULSE Laser Cleaner
  • Optical Pump: JPT
  • 300W Output
  • Air-Cooled
  • 240V input
$14,499.00You Save - $1,000.00
$13,499.00 Buy Now
RedSabre 500CP Heavy-Duty PULSE Laser Cleaner
  • Optical Pump: JPT
  • 500W Output
  • Air-Cooled
  • Steel case design
  • Touch screen
  • Rolling Cabinet Design
  • 240V input
$27,999.00 Buy Now
