Water Cooler for Welders
PowerCool W300 (240V)
  • Compact design
  • Large Fan
  • Stainless Steel Pump
  • Copper Radiator
  • Sealed Industrial motor
  • Color coded quick couplers
$499.00 Buy Now
Construction:
  • Stainless pump
  • Sealed Industrial Motor
  • Copper Radiator
Gal/min:
.26 gpm
Price: $499.00
  • 2+ gallon reservoir
  • Stainless pump
  • Sealed motor
PowerCool W401 (240V)
  • Compact design
  • Large Fan
  • Copper Radiator
  • Plug and Play for Hurricane 220 MTS-CLightning MTS 225Lightning MTS 275 and Power i-MIG 353DPi
$599.00 Buy Now
Construction:
  • Stainless pump
  • Copper Radiator
Gal/min:
.26 gpm
Price: $599.00
  • Stainless pump
  • Sealed motor
PowerCool W375 (240V)
  • Fits PowerARC 280STH.
  • Compact design.
  • Large Fan.
  • Copper Radiator.
  • Sealed Industrial motor.
  • Color coded quick couplers.
  • Will not fit PowerCart 250.
$499.00 Buy Now
Construction:
  • Stainless pump
  • Copper Radiator
Gal/min:
2.2 GPM/8.5 LPM (Free Flow)
Price: $499.00
  • Stainless pump
  • Sealed motor
PowerCool W400 (240V)
  • Compact design
  • Large Fan
  • Copper Radiator
$599.00 Buy Now
Construction:
  • Stainless pump
  • Copper Radiator
Gal/min:
.26 gpm
Price: $599.00
  • Stainless pump
  • Sealed motor
PowerCool W500 (240V)
  • Compact design
  • Large Fan
  • Copper Radiator
Construction:
  • Stainless pump
  • Copper Radiator
Gal/min:
.26 gpm
  • Stainless pump
  • Sealed motor
PowerCool W350 (120V)
  • Compact design
  • Large Fan
  • Copper Radiator
  • Miller style quick couplers
$499.00 Buy Now
Water Cooler 120V
Construction:
  • Stainless pump
  • Copper Radiator
Gal/min:
.26 gpm
Price: $499.00
  • LH 5/8-18 Fittings
  • Stainless pump
  • Sealed motor
