TIG Welders
TIG Welders
PowerArc 140STi
  • Dependable IGBT inverter
  • New Digital internal design
  • 120V/240V Dual Voltage
  • Adjustable Hot Start
  • Impact resistant carry case
  • CC
$349.00 Buy Now
SMAW/ GTAW (DC only)
5A
80/140A (120/240V)
35%
Price: $349.00
  • Self contained carry case
PowerArc 160iSTH
  • DC Stick/TIG functions
  • Foot Pedal capable
  • CC
$489.00You Save - $80.00
$409.00 Buy Now
SMAW/GTAW (DC Only)
120V/240V 1 Ph 50/60 Hz
10 Amps
160 Amps
35%
Price: $409.00
  • Dual Voltage
PowerArc 161STH
  • Auto-adaptive Hot Start
  • CC
$569.00You Save - $20.00
$549.00 Buy Now
SMAW/GTAW (DC Only)
10 Amps
160 Amps
35%
Price: $549.00
  • Dual Voltage
PowerArc 200STi
  • 1 amp increment adjustment
  • CC
$399.00You Save - $-50.00
$449.00 Buy Now
SMAW/GTAW (DC Only)
120V/240V 1 Ph 50/60Hz
10A
120V: 120A, 240V: 200A
35%
Price: $449.00
  • E6010/Cellulosic feature
PowerArc 210STL
  • Pedal/2T/4T function
  • Optional Foot Pedal
  • CC
$499.00 Buy Now
SMAW/GTAW (DC Only)
10A
35%
Price: $499.00
PowerArc 280STH
  • Reliable IGBT Power Modules
  • 35% duty cycle
  • 250A DC Stick/280A DC TIG
  • 1 and 3 phase input capable
  • CC
$1,189.00 Buy Now
SMAW-GTAW-P (DC Only)
240V 1/3 PH 50/60Hz
5A
250A Stick/280A TIG
35%
Price: $1,189.00
  • Infineon IGBT modules
PowerArc 300ST
  • Dedicated Setting for E6010
  • DC Lift TIG capable
  • CC
$849.00 Buy Now
SMAW/GTAW (DC Only)
  • DC Lift TIG function
20 Amps
300 Amps
Price: $849.00
  • Lift TIG capable
  • E6010/Cellulosic capable
Power i-TIG 200T
  • Digitally controlled  IGBT Inverter
  • 35% Duty Cycle at 200 Amps (240V)
  • DC TIG/ DC Stick functions
  • HF or Lift TIG start
  • Programmable Pulse to 500Hz
  • Adjustable Stick Hot Start/Arc Force
  • 9 Channel Memory
  • Down to 3 Amp operation
  • Compact design
  • CC
$829.00You Save - $140.00
$689.00 Buy Now
GTAW-P/ SMAW (DC Only)
120/240V 1Phase 50/60 Hz
3 Amps
35%
Price: $689.00
  • Stable DC output
  • Low amp operation down to 3 amps
  • Pulse up to 500 Hz
  • 9 Channel Memory
Power i-TIG 201
  • Analog style panel, digital control
  • Commercial, 35% Duty Cycle at 200 amps
  • DC TIG/DC Stick functions
  • HF or Lift TIG Start
  • Pulse up to 250Hz
  • Adjustable Stick Arc Force
  • Down to 5 amp start/operation
  • 120V/240V operation
  • CC
$699.00You Save - $130.00
$569.00 Buy Now
GTAW-P/SMAW (DC Only)
120/240V 1 Ph 50/60 Hz
5 Amps
200A TIG
35%
Price: $569.00
  • Analog input/Digital Control provides well liked combination
  • Feature Packed with Pulse and 2T/4T controls
  • Down to 5 amp operation (+/- 2A)
  • Stable DC arc
PowerTIG 185DV
  • Analog style controls
  • 35% Duty Cycle at 185 Amps/ 240V
  • 35% Duty Cycle at 125 Amps/ 120V
  • AC/DC TIG, DC Stick functions
  • Simple to use TIG pulse @ 1 or 50 Hz
  • AC Frequency/Balance control
  • Standard AC Advanced Square Wave
  • HV Start (Solid State HF Type)
  • CC
$899.00You Save - $124.00
$775.00 Buy Now
GTAW-P/ SMAW
120/240V 1 Phase 50/60 Hz
5A DC/ 20A AC (+/- 3A)
120V: 125A TIG/100A Stick, 240V: 200A TIG/150A Stick
35%TIG/Stick
Price: $775.00
  • Dual Voltage 120V/240V input improves portability
  • Simplified Pulse Setup, 1 or 50 Hz
  • Basic design AC/DC welder
  • AC Frequency and Balance control for maximum arc control while welding
  • Stick Weld function
  • NOVA SuperFlex torch and NOVA pedal INCLUDED
PowerTIG 200DV
  • Industrial 60% Duty Cycle at 200 amps
  • AC/DC TIG/DC Stick functions
  • HV and Lift TIG start
  • Fan and Cooler Control Technology
  • Pulse up to 150Hz in AC or DC
  • Standard Advanced AC Square Wave
  • Arc force control for Stick
  • CC
$1,349.00You Save - $270.00
$1,079.00 Buy Now
GTAW-P/ SMAW
5A DC/20A AC
125A/200A (120V/240V)
Price: $1,079.00
  • Dual Voltage input
  • Pulse Frequency up to 150 Hz
  • Analog, easy to use controls
  • AC Frequency and AC balance controls
PowerTIG 210EXT
  • 120/240V IGBT Module inverter design
  • PFC (Power Factor Correction)
  • Digital Microprocessor Control
  • Commercial 60% Duty Cycle at 210 Amps
  • Improved Heavy Duty HF Start
  • 3 wave AC Wave forms, Advanced Square, Soft Square, and Triangular
  • Standard and Advanced AC pulse
  • 9 Channel Programmable Memory
  • Electronic HV Start replaces older HF point gap starting
  • Fan runs on demand when arc starts and terminates automatically after arc stops.
  • CC
$1,799.00You Save - $330.00
$1,469.00 Buy Now
GTAW-P/SMAW
120/240V 1 Phase 50/60Hz
3/5A, AC/DC
210 A
  • 60%.@ 210A TIG
  • 60% @ 160A Stick
Price: $1,469.00
  • AC wave form control
  • Standard Pulse for AC/DC modes
  • Advanced Pulse for AC
  • 9 Channel Memory
PowerTIG 250EX
  • Rugged IGBT Module inverter
  • Simple Analog Input, Reliable Digital Control of parameters
  • Industrial 60% Duty Cycle at 250 Amps
  • AC/DC TIG/ DC Stick functions
  • Pulse up to 500 Hz  in AC or DC
  • Arc force control
  • Spot weld timer
  •  HV Start.(Solid State HF Type)
  •  Fan-On-Demand
  • CC
$1,699.00You Save - $250.00
$1,449.00 Buy Now
GTAW-P/SMAW
240V 1/3 Phase 50/60Hz
5 amps (+/- 2A)
250 Amps
Price: $1,449.00
  • Digitally controlled inverter
  • Analog style input
  • AC/DC with up to 500 Hz Pulse
  • AC Frequency and Balance Control
PowerTIG 255EXT
  • Rugged Digital IGBT Inverter
  • Pulse up to 500 Hz DC; 250 Hz AC
  • Advanced Square, Soft Square, Triangular, and Sine wave forms
  • Adjustable Stick Arc force and Hot Start Control
  • Advanced AC Pulse
  • 120V/240V Operation
  • CC
$2,499.00You Save - $524.00
$1,975.00 Buy Now
GTAW-P/ SMAW
3A DC, 5A AC
250 Amps
Price: $1,975.00
  • Precise control over all parameters
  • AC Wave form control
  • Advanced AC pulse/ Standard AC/DC pulse
  • Adjustable Stick Arc Force and Hot Start
  • 120V/240V operation (New for 2015)
  • 6010 stick operation capability
PowerTIG 315LX
  • Analog Input with Digital Control
  • Industrial 60% Duty Cycle at 315 Amps
  • Pulse up to 750Hz in AC or DC
  • AC Frequency control up to 500Hz
  • AC Balance control 10-90%
  • Stick Arc Force control
  • New, compact case design
  • Fan on demand
  • CC
$1,999.00You Save - $300.00
GTAW-P/ SMAW
240V 1 Ph 50/60 Hz
5A DC/ 20A AC
315 Amps
TIG: 60%, Stick 35% at Max. Amps
  • Industrial class analog inverter
  • AC frequency control up to 500Hz
  • Pulse up to 750 Hz
  •  240V 1 phase input
PowerTIG 325EXT (~1 and 3 Phase 240V)
  • Rugged IGBT Module Inverter
  • Adjustable Arc force and Hot Start
  • 9 programmable channels to save favorite settings
  • Advanced AC Pulse
  • 240V 1 ph
  • CC
$2,799.00You Save - $700.00
$2,099.00 Buy Now
GTAW-P/ SMAW
240V 1 and 3 Ph 50/60Hz
5A DC, 10A AC
325 Amps
35%
Price: $2,099.00
  • Advanced AC pulse and AC/DC Standard Pulse
  • Wide range of features including memory, 2T/4T control
  • Adjustable Stick Arc force and Hot Start features
  • 240 1 and 3 Phase
PowerTIG 325EXT (~3 Phase 480V)
  • Advanced AC Pulse
  • 480V 3 phase input
  • CC
$2,925.00You Save - $626.00
GTAW-P/ SMAW
 480V 3 ph
5A DC/10A AC
325A TIG/ 250 Stick
35%
  • Advanced AC pulse/AC/DC Standard Pulse
  • 480V 3 phase
PowerTIG 400EXT
  • Commercial-level 35% Duty Cycle at 400 Amps
  • Advanced AC Pulse
  • 240V 1 and 3 Phase Operation
  • Electronic HV Start replaces older HF point gap starting.
  • CC
$3,699.00You Save - $700.00
GTAW-P/ SMAW
5A DC, 10A AC
400 Amps
35%
  • 240V 1 phase
PowerTIG 400EXT (3Ph 480V)
  • Advanced AC Pulse
  • 3 Phase 480V Power Input and Operation
  • HF point gap starting
  • Fan runs continuously
  • CC
$3,949.00You Save - $650.00
$3,299.00 Buy Now
GTAW-P/ SMAW
480V  3 Ph 50/60Hz
5A DC, 10A AC
400 Amps
35%
Price: $3,299.00
  • 480V 3 phase
Typhoon 230
  • 230 Amp AC/DC Pulse TIG, 200 Amp AC/DC Stick.
  • Large 5.1" Hi Definition LCD color screen.
  • Independent Amperage adjustment for EP and EN half cycles (Independent Amplitude).
  • Split wave form control for AC.
  • 2 Amp DC and 3 Amp AC Start.
  • Up to 400 Hz AC frequency.
  • DC pulse wave form shaping.
  • Standard and Adv. AC pulse
  • Standard AC Pulse Freq. 400 Hz
  • Adv. AC Pulse 10 Hz
  • DC Pulse Frequency 999.9 Hz
  • 5 AC wave forms.
  • Advanced Power Set Mode for easy setup.
  • No pop-up screens.  Easy to navigate.
  • All main settings visible at a glance.
  • Fan and Cooler Control Technology.
  • 70% Duty Cycle at max output.
  • Dual Voltage 120/240V, auto sensing.
  • CC
$3,750.00You Save - $1,251.00
$2,499.00 Buy Now
GTAW/SMAW
120/240V
DC 3A; AC 5A
70%
70% @ Max 120/240V
Price: $2,499.00
5 Wave Form Controls for AC
AC Amplitude Control
Split Wave Form Control
DC Pulse Wave form shaping
High Duty Cycle
5.1 HD (720) TFT Screen
Typhoon 330 (1Ph/3Ph 240V)
  • 330 Amp AC/DC Pulse TIG, 250 Amp AC/DC Stick.
  • 220/240V 1 and 3 Phase
  • 3A Start AC/ 2A Start DC
  • 5 AC wave forms.
  • CC
$4,299.00You Save - $1,049.00
$3,250.00 Buy Now
GTAW/SMAW
240V 1 and 3 Phase
480V opt.
2/3A
2/3-330A
40% @ Max Output
Price: $3,250.00
  • Large HD 5.1" lcd screen
  • AC/DC TIG and AC/DC Stick
  • 5 AC wave forms
Typhoon 330 (3Ph 480V)
  • 480V 3 Phase only
  • 5 AC wave forms.
  • CC
$4,599.00You Save - $1,149.00
$3,450.00 Buy Now
GTAW/SMAW
480V 3 Phase
480V opt.
2/3A
2/3-330A
40% @ Max Output
Price: $3,450.00
  • Large HD 5.1" LCD screen
  • 5 AC wave forms
Typhoon 500
  • 500 A AC/DC Pulse TIG, 400 A AC/DC Stick (480V 3 phase)
  • 400A AC/DC Pulse TIG, 315A AC/DC Stick (240V 1 phase)
  • Large 720P High Definition LCD color screen
  • 10A Start AC/ 5A Start DC
  • 5 AC wave forms
  • Includes Cooler and Cart
  • CC
$6,599.00You Save - $100.00
$6,499.00 Buy Now
GTAW/SMAW
240V 1 phase and 480V 3 Phase
5/10A
240V 1 ph: 5/10- 400A
480V 3 ph: 5/10-500A
60% @ Max Output
Price: $6,499.00
  • Large HD LCD screen
  • 5 AC wave forms
Need a TIG?
Don’t need to weld Aluminum?
5 Year Warranty
