plasma cutters
Plasma Cutters
  • Rugged IGBT construction
  • Blow-back start technology
  • Pilot Arc
  • ~3 Phase 480V input
  • CC
$2,259.00You Save - $60.00
PAC CNC
480V 3 Ph 50/60Hz
20 Amps
100 Amps
60% @ 100 Amps
PowerPlasma 52i
  • NEW! Gouge Function
  • Replaces PowerPlasma 50
  • CC
$949.00You Save - $150.00
$799.00 Buy Now
PAC
120V/240V 1 Ph 50/60 Hz
20 Amps
50 Amps
60% Duty Cycle at 50 Amps
Price: $799.00
PowerPlasma 25i XTR
  • 120V Input
  • 10-25A Output
  • Innotect iPT 25 Torch
  • Blow-Back Start
  • Small, compact
  • CC
$589.00You Save - $130.00
$459.00 Buy Now
PAC
120V
10A
25A
35%
Price: $459.00
Compact, versatile 120V unit
  • ~1/ 3 Phase 240V input
  •  IGBT module construction
  • 60% Duty Cycle at 100 Amps
  • CC
$1,899.00You Save - $100.00
PAC
1/3 Phase 220-240V
20 Amps
100 A
60% @ 100 Amps
  • Blowback start
  • Pilot Arc
  • 240V 1 phase input
  • CC
$1,649.00You Save - $180.00
$1,469.00 Buy Now
PAC CNC
20 Amps
80 Amps
60% @ 80 Amps
Price: $1,469.00
  • CC
$1,899.00You Save - $-100.00
$1,999.00 Buy Now
PAC
3 Phase 480V
20 Amps
100 A
60% @ 100 Amps
Price: $1,999.00
  • Blowback start
PowerPlasma 62i
  • Super-Bright Display
  • PT/iPT 60 Torch
  • CC
PAC
20 Amps
60 Amps
60% @ 60 Amps
  • Innotec iPT 60 torch
Hatchet 60
  • 60 Amps of Cutting Power
  • Not for CNC use
  • PT/iPT 60 Torch
  • CC
$899.00You Save - $250.00
PAC
20A
120V: 30A; 240V 60A
35% @ Max Output
  • Low air pressure cut out
  • PT/iPT 60 torch
  • Compact Size
  • Pilot Arc
  • ~1/3 Phase 240V input
  • CC
$2,259.00You Save - $260.00
$1,999.00 Buy Now
PAC CNC
240V 1/3 Ph 50/60Hz
20 Amps
100 Amps
60% @ 100 Amps
Price: $1,999.00
  • 60 Amp CNC package
  • Pilot Arc
  • iPTM 60M CNC torch
  • CC
$1,420.00You Save - $170.00
$1,250.00 Buy Now
PAC CNC
20 Amps
60 Amps
60% @ 60 Amps
Price: $1,250.00
  • PT/iPT 60 torch
PowerPlasma 150H
  • CC
$3,499.00 Buy Now
PAC
Price: $3,499.00
PowerPlasma 82i
  • 80 Amps @ 60% Duty Cycle
  • Pilot Arc
  • Digital Air Pressure Gauge
  • Super Bright Display
  • Gouge mode
  • CC
$1,349.00You Save - $80.00
$1,269.00 Buy Now
PAC
20 Amps
80 Amps
60% @ 80 Amps
Price: $1,269.00
