Multi Process: MIG/TIG/Stick
Tempest 401i
  • IP23 Contstruction
  • 480V 3 phase operation
$3,999.00You Save - $200.00
$3,799.00 Buy Now
Price: $3,799.00
PowerMTS 141Si
  • Simple Control Layout
  • 120V Input Operation
GMAW, GTAW (DC), SMAW (DC)
120V 1 Phase
30A MIG/ 10A TIG/ 20A Stick
140A MIG/TIG, 80A Stick
25%
  • 2T and 4T operation
  • Foot pedal optional
