Water Cooler for Welders
Keep your torch cool with an industrial quality cooler
The PowerCool line of water coolers from Everlast is the final purchase needed to complete and improve your Everlast TIG welding experience. Anything over 200 amps of output requires a water-cooled torch and a watercooler for TIG welding. Everlast water coolers for welding can also keep water cooled MIG torches cool as well and can be fitted to almost any MIG gun or TIG welding torch. These units feature industrial level water cooling performance for TIG welders up to 350 amps. Equipped with an Italian made stainless steel water pump and sealed industrial motor, these PowerCool water coolers are equipped to cool efficiently and quietly. For long term service and maximum heat transfer ability, the units also feature a copper-core radiator. Compare this to other name brand coolers, and you’ll often find cheaper, less efficient all aluminum radiators which are more prone to corrosion.
The PowerCool water coolers feature a universal design will work with other brands
Since we offer our coolers in dual voltage and single voltage configurations, the Everlast Power Cool will work with almost any brand. With our small foot print and square box like shape, these units take up little space, in can be made to fit conveniently on most carts and shelfs, near the welder. These units do feature color-coded quick connect style fittings on the front of the units which simplifies the connection and down time required while changing or moving torches. The quick connect adapters are available through Everlast directly to fit almost any TIG or MIG torch. Be sure to inquire at the time of purchase if you are calling in to place your purchase.
Stay cool TIG welding with quality
Everlast PowerCool TIG welding water coolers carry the same 5 year parts and labor warranty as our TIG and MIG welders. So if you are worried about buying a disposable water cooler, don’t. We believe that our coolers are made with quality and will stand up to years of daily use. But in case they don’t, we’ve got you covered with our industry leading, 5 year standard warranty.
