Multi Process: MIG/TIG/Stick
PowerMTS 141Si
  • Simple Control Layout
  • 120V Input Operation
$649.00You Save - $50.00
$599.00 Buy Now
GMAW, GTAW (DC), SMAW (DC)
120V 1 Phase
30A MIG/ 10A TIG/ 20A Stick
140A MIG/TIG, 80A Stick
25%
Price: $599.00
  • 2T and 4T operation
  • Foot pedal optional
$1,499.00You Save - $249.00
$1,250.00 Buy Now
Price: $1,250.00
$3,000.00 Buy Now
Price: $3,000.00
Tempest 401i
  • IP23 Contstruction
  • 480V 3 phase operation
$3,999.00You Save - $200.00
$3,799.00 Buy Now
Price: $3,799.00
$1,999.00You Save - $350.00
$1,649.00 Buy Now
Price: $1,649.00
Lightning 212 MTS
  • Dual, 120-240V Input
  • AC/DC Pulse TIG and DC Stick
  • Uses Spool Gun for MIG (No internal wire feeder)
  • 60% Duty Cycle @ 210A MIG, 250TIG, 170A Stick
  • Adjustable MIG Inductance/Stick Arc Force
  • Uses Parker DSP 240 Spool Gun (Recommended)
  • Can be used for MIG with Steel, Stainless and Aluminum.
  • 4" spool (2 lbs./Steel, 1 lb/Aluminum) capacity
  • Synergic PowerSet function simplifies setup in all processes
$1,869.00You Save - $120.00
$1,749.00 Buy Now
GMAW (Spool Gun Only)/GTAW-P/ SMAW
Price: $1,749.00
$2,499.00You Save - $499.00
$2,000.00 Buy Now
Price: $2,000.00
$2,999.00You Save - $649.00
$2,350.00 Buy Now
Price: $2,350.00
$3,399.00You Save - $799.00
$2,600.00 Buy Now
GMAW-P/GTAW-P/SMAW
Price: $2,600.00
