Laser Cleaners
RedSabre 1500XC
  • Optical Pump: GW
  • 1500W Output
  • Continuous Wave Laser Cleaning
  • Air-Cooled
  • Pulsing up to 3000 kHz
  • Handheld Scanning Gun
  • Double Scan Head BTW30C
  • Water-Cooled Design
  • 240V input
  • Scan Range up to 150mm wide on X axis
$11,500.00 Buy Now
RedSabre 300CP PULSE Laser Cleaner
  • Optical Pump: JPT
  • 300W Output
  • Pulsed Fiber Laser Cleaning
  • Air-Cooled
  • Multiple Scan Pattern Shapes
  • Steel case design
  • Portable Touch screen
  • Compact, table top size
  • Hand Held Scanning Gun
  • 240V input
  • 5m (16 ft.) fiber cable
  • Scan Range up to 160mm wide on X axis
  • Scan Range up to 120mm wide on Y axis
$15,718.00You Save - $2,719.00
$12,999.00 Buy Now
RedSabre 301CP Heavy-Duty PULSE Laser Cleaner
  • Optical Pump: JPT
  • 300W Output
  • Air-Cooled
  • Up to 3000Khz pulse
  • Multiple Scan Pattern Shapes for improved cleaning on shaped and irregular surfaces
  • Impact resistant plastic "suitcase" design
  • 240V input
  • Scan Range up to 160mm wide X axis
$17,398.00You Save - $3,899.00
$13,499.00 Buy Now
RedSabre 2000XC
  • Optical Pump: GW
  • 2000W Output
  • Air-Cooled
  • 240V input
$13,500.00 Buy Now
RedSabre 500CP Heavy-Duty PULSE Laser Cleaner
  • Optical Pump: JPT
  • 500W Output
  • Air-Cooled
  • Pulsing up to 2500 kHz
  • Steel case design
  • Touch screen
  • Rolling Cabinet Design
  • 240V input
  • Scan Range up to 200mm (7.9") wide, depending upon focus lens
$27,999.00 Buy Now
RedSabre 201CP Heavy-Duty PULSE Laser Cleaner
  • Optical Pump: JPT
  • 200W Output
  • Air-Cooled
  • Up to 2500Khz pulse
  • Portable Touch Screen
  • 240V input
  • Scan Range up to 100mm wide
$17,398.00You Save - $4,899.00
$12,499.00 Buy Now
RedSabre 200CP PULSE Laser Cleaner
  • Optical Pump: JPT
  • 200W Output
  • Air-Cooled
  • Steel case design
  • 240V input
$15,658.00You Save - $3,659.00
$11,999.00 Buy Now
