Stick Welders
Stick Welders
Skyliner 400S
  • Heavy duty IGBT inverter output
  • 240V 1 Phase 480V 3 phase Stick Output
  • 60% Duty cycle at 315A (240V 1 phase) and 400A (480V 3Ph)
  • 90V OCV
  • Adjustable Hot Start
  • Adjustable Arc Force
  • Scratch Start TIG only
  • Stick/Air Carbon Arc Gouging Rated
  • CC
$1,500.00You Save - $101.00
$1,399.00 Buy Now
SMAW/ ACAC
Price: $1,399.00
PowerArc 140STi
  • Dependable IGBT inverter
  • New Digital internal design
  • 120V/240V Dual Voltage
  • Impact resistant carry case
  • CC
$349.00 Buy Now
SMAW/ GTAW (DC only)
5A
80/140A (120/240V)
35%
Price: $349.00
  • Self contained carry case
PowerArc 160iSTH
  • DC Stick/TIG functions
  • Foot Pedal capable
  • CC
$489.00You Save - $80.00
$409.00 Buy Now
SMAW/GTAW (DC Only)
120V/240V 1 Ph 50/60 Hz
10 Amps
160 Amps
35%
Price: $409.00
  • Dual Voltage
PowerArc 161STH
  • Auto-adaptive Hot Start
  • CC
$569.00You Save - $100.00
$469.00 Buy Now
SMAW/GTAW (DC Only)
10 Amps
160 Amps
35%
Price: $469.00
  • Dual Voltage
PowerArc 200STi
  • 1 amp increment adjustment
  • CC
$499.00You Save - $50.00
$449.00 Buy Now
SMAW/GTAW (DC Only)
120V/240V 1 Ph 50/60Hz
10A
120V: 120A, 240V: 200A
35%
Price: $449.00
  • E6010/Cellulosic feature
PowerArc 210STL
  • Pedal/2T/4T function
  • Optional Foot Pedal
  • CC
$499.00You Save - $60.00
$439.00 Buy Now
SMAW/GTAW (DC Only)
10A
35%
Price: $439.00
PowerArc 280STH
  • Reliable IGBT Power Modules
  • 35% duty cycle
  • 250A DC Stick/280A DC TIG
  • 1 and 3 phase input capable
  • CC
$1,189.00 Buy Now
SMAW-GTAW-P (DC Only)
240V 1/3 PH 50/60Hz
5A
250A Stick/280A TIG
35%
Price: $1,189.00
  • Infineon IGBT modules
PowerArc 300ST
  • Dedicated Setting for E6010
  • DC Lift TIG capable
  • CC
$849.00You Save - $70.00
$779.00 Buy Now
SMAW/GTAW (DC Only)
  • DC Lift TIG function
20 Amps
300 Amps
Price: $779.00
  • Lift TIG capable
  • E6010/Cellulosic capable
