$399.00You Save - $20.00
$379.00 Buy Now
Price: $379.00
  • Heavy duty wire feed
$639.00You Save - $50.00
$589.00 Buy Now
Price: $589.00
$1,199.00You Save - $199.01
$999.99 Buy Now
Price: $999.99
  • MIG and Stick function
Cyclone 262i
$1,549.00You Save - $349.00
$1,200.00 Buy Now
Price: $1,200.00
$1,999.00You Save - $300.00
Cyclone 373DPi
  • 60% Duty Cycle at 375A
  • 240V 1 and 480V 3 Phase (plug not included)
  • FCAW-G (Gas shielded Flux-Cored)
  • FCAW (Self-shielded Flux-Cored)
  • Split control of weld functions. Wire feeder controls all MIG functions, Power Source controls Stick and TIG
  • Both Power Source and Wire Feeder feature LCD control screens
  • 15 Ft. Water-Cooled 510 series MIG gun, setup for Aluminum (Steel liner included)
  • Separate, detachable wire-feeder
  • Cart Included
  • Water-Cooler Included
  • 4.3" HD LCD Color Display on Power Source
  • 5.1" HD LCD Color Display on Wire Feeder
$4,999.00You Save - $500.00
$4,499.00 Buy Now
Price: $4,499.00
  • UPDATED: 60% Duty Cycle at 275A
$2,399.00You Save - $200.00
$1,999.00You Save - $350.00
$1,649.00 Buy Now
Price: $1,649.00
Cyclone 313Pi
  • Single Pulse MIG/MIG/Stick
  • Spool Gun and Push Pull Gun ready
  • .035"-.045" wire diameter standard
  • Use up to .062" wire
  • 36 series MIG Gun with Euro Quick Connect
  • Large 5.1" TFT HD LCD Screen
$2,799.00You Save - $400.00
$2,399.00 Buy Now
Price: $2,399.00
$7,299.00You Save - $1,100.00
$6,199.00 Buy Now
Price: $6,199.00
$1,649.00 Buy Now
Price: $1,649.00
$3,000.00 Buy Now
Price: $3,000.00
$2,999.00You Save - $649.00
$2,350.00 Buy Now
Price: $2,350.00
  • 24 series MIG Gun
  • IPT-40 Plasma Blow back torch
$2,999.00You Save - $549.00
$2,450.00 Buy Now
Price: $2,450.00
$1,499.00You Save - $249.00
$1,250.00 Buy Now
Price: $1,250.00
$3,399.00You Save - $799.00
$2,600.00 Buy Now
GMAW-P/GTAW-P/SMAW
Price: $2,600.00
