TIG Welders
TIG Welders
POWERARC 140ST
  • Dependable IGBT inverter
  • 120V/240V Dual Voltage
  • Auto-adaptive Hot Start
  • Impact resistant carry case
  • CC
$279.00 Buy Now FINANCE
SMAW/ GTAW (DC only)
PowerArc 140ST
10A
85/140A (120/240V)
35%
Price: $279.00
  • Compact IGBT inverter
  • Self contained carry case
POWERARC 160STH
  • DC Stick/TIG functions
  • Foot Pedal capable
  • CC
$489.00 Buy Now FINANCE
SMAW/GTAW (DC Only)
PowerARC 160STH Front View
120V/240V 1 Ph 50/60 Hz
10 Amps
160 Amps
35%
Price: $489.00
  • Dual Voltage
POWERARC 200ST
  • Dedicated connection port for E6010
  • DC Stick/Lift TIG functions
  • Auto-adaptive hot start
  • CC
$399.00 Buy Now FINANCE
SMAW/GTAW (DC Only)
Main view of the PowerARC 200ST
120V/240V 1 Ph 50/60Hz
20A
120V: 120A, 240V: 200A
35%
  • E6010/Cellulosic capability with separate 6010 port
PowerARC 300ST
  • Adjustable Hot Start
  • DC Lift TIG capable
  • CC
$619.00 Buy Now FINANCE
SMAW/GTAW (DC Only)
Front main view of the PowerARC 300ST
  • DC Lift TIG function
20 Amps
300 Amps
  • Lift TIG capable
  • E6010/Cellulosic capable
Power i-TIG 201
  • Analog style panel, digital control
  • Commercial, 35% Duty Cycle at 200 amps
  • DC TIG/DC Stick functions
  • HF or Lift TIG Start
  • Pulse up to 250Hz
  • Adjustable Stick Arc Force
  • Down to 5 amp start/operation
  • 120V/240V operation
  • CC
$699.00 Buy Now FINANCE
GTAW-P/SMAW (DC Only)
Power i-TIG 201
120/240V 1 Ph 50/60 Hz
5 Amps
200A TIG
35%
Price: $699.00
  • Analog input/Digital Control provides well liked combination
  • Feature Packed with Pulse and 2T/4T controls
  • Down to 5 amp operation (+/- 2A)
  • Stable DC arc
Power i-TIG 200T
  • Digitally controlled  IGBT Inverter
  • 35% Duty Cycle at 200 Amps (240V)
  • DC TIG/ DC Stick functions
  • HF or Lift TIG start
  • Programmable Pulse to 500Hz
  • Adjustable Stick Hot Start/Arc Force
  • 9 Channel Memory
  • Down to 3 Amp operation
  • Compact design
  • CC
$829.00 Buy Now FINANCE
GTAW-P/ SMAW (DC Only)
Power i-TIG 200T Front main view
120/240V 1Phase 50/60 Hz
3 Amps
35%
Price: $829.00
  • Stable DC output
  • Low amp operation down to 3 amps
  • Pulse up to 500 Hz
  • 9 Channel Memory
PowerTIG 185 (DV)
  • Analog style controls
  • 35% Duty Cycle at 185 Amps/ 240V
  • 35% Duty Cycle at 125 Amps/ 120V
  • AC/DC TIG, DC Stick functions
  • Simple to use TIG pulse @ 1 or 50 Hz
  • AC Frequency/Balance control
  • Standard AC Advanced Square Wave
  • CC
$899.00 Buy Now FINANCE
GTAW-P/ SMAW
PowerTIG 185DV Front Main View
120/240V 1 Phase 50/60 Hz
5A DC/ 20A AC (+/- 3A)
120V: 125A TIG/100A Stick, 240V: 200A TIG/150A Stick
35%TIG/Stick
Price: $899.00
  • Dual Voltage 120V/240V input improves portability
  • Simplified Pulse Setup, 1 or 50 Hz
  • Basic design AC/DC welder
  • AC Frequency and Balance control for maximum arc control while welding
  • Stick Weld function
PowerTIG 200DV
  • Industrial 60% Duty Cycle at 200 amps
  • AC/DC TIG/DC Stick functions
  • HF and Lift TIG start
  • Pulse up to 150Hz in AC or DC
  • Standard Advanced AC Square Wave
  • Arc force control for Stick
  • CC
$1,349.00 Buy Now FINANCE
GTAW-P/ SMAW
PowerTIG 200DV main front view
5A DC/20A AC
125A/200A (120V/240V)
Price: $1,349.00
  • Dual Voltage input
  • Pulse Frequency up to 150 Hz
  • Analog, easy to use controls
  • AC Frequency and AC balance controls
PowerTIG 210 EXT
  • 120/240V IGBT Module inverter design
  • Digital Microprocessor Control
  • Commercial 60% Duty Cycle at 210 Amps
  • Improved HF Start
  • 3 wave AC Wave forms, Advanced Square, Soft Square, and Triangular
  • Standard and Advanced AC pulse
  • 9 Channel Programmable Memory
  • CC
$1,799.00 Buy Now FINANCE
GTAW-P/SMAW
PowerTIG 210EXT
120/240V 1 Phase 50/60Hz
3/5A, AC/DC
210 A
60%.@ 210A TIG
  • AC wave form control
  • Standard Pulse for AC/DC modes
  • Advanced Pulse for AC
  • 9 Channel Memory
PowerTIG 250EX
  • Rugged IGBT Module inverter
  • Simple Analog Input, Reliable Digital Control of parameters
  • Industrial 60% Duty Cycle at 250 Amps
  • AC/DC TIG/ DC Stick functions
  • Pulse up to 500 Hz  in AC or DC
  • Arc force control
  • Spot weld timer
  • CC
$1,699.00 Buy Now FINANCE
GTAW-P/SMAW
PowerTIG 250EX Front View
240V 1/3 Phase 50/60Hz
5 amps (+/- 2A)
250 Amps
  • Digitally controlled inverter
  • Analog style input
  • AC/DC with up to 500 Hz Pulse
  • AC Frequency and Balance Control
PowerTIG 350EXT
  • Rugged Digital IGBT Inverter
  • Commercial-level 35% Duty Cycle at 350 Amps
  • Solid State HF or Lift TIG start
  • Pulse up to 500 Hz DC; 250 Hz AC
  • Advanced Square, Soft Square, Triangular, and Sine wave forms
  • Adjustable Stick Arc force and Hot Start Control
  • Advanced AC Pulse
  • 240V 1 Phase Operation
  • CC
$2,999.00 Buy Now FINANCE
GTAW-P/ SMAW
5A DC, 10A AC
350 Amps
35%
  • Precise control over all parameters
  • AC Wave form control
  • Advanced AC pulse/ Standard AC/DC pulse
  • Adjustable Stick Arc Force and Hot Start
  • 240V 1 phase
  • 6010 stick operation capability
PowerARC 280STH
  • Reliable IGBT Power Modules
  • 35% duty cycle
  • 250A DC Stick/280A DC TIG
  • 1 and 3 phase input capable
  • CC
$1,189.00 Buy Now FINANCE
SMAW-GTAW-P (DC Only)
PowerARC 280STH front main view
240V 1/3 PH 50/60Hz
5A
250A Stick/280A TIG
35%
Price: $1,189.00
  • Infineon IGBT modules
PowerTIG 255EXT
  • Advanced AC Pulse
  • 120V/240V Operation
  • CC
$2,499.00 Buy Now FINANCE
GTAW-P/ SMAW
PowerTIG 255EXT Front
3A DC, 5A AC
250 Amps
Price: $2,499.00
  • 120V/240V operation (New for 2015)
PowerTIG 315LX
  • Analog Input with Digital Control
  • Industrial 60% Duty Cycle at 315 Amps
  • Pulse up to 750Hz in AC or DC
  • AC Frequency control up to 500Hz
  • AC Balance control 10-90%
  • Stick Arc Force control
  • CC
$1,999.00 Buy Now FINANCE
GTAW-P/ SMAW
315LX Front
240V 1 Ph 50/60 Hz
10A DC/ 20A AC
315 Amps
TIG: 60%, Stick 35% at Max. Amps
Price: $1,999.00
  • Industrial class analog inverter
  • AC frequency control up to 500Hz
  • Pulse up to 750 Hz
  •  240V 1 phase input
PowerTIG 325EXT (240V 1 phase and 240V 3 phase)
  • Rugged IGBT Module Inverter
  • Adjustable Arc force and Hot Start
  • 9 programmable channels to save favorite settings
  • Advanced AC Pulse
  • 240V 1 and 3 ph
  • CC
$2,799.00 Buy Now FINANCE
GTAW-P/ SMAW
Front View of PowerTIG 325EXT
240V 1 and 3 Ph 50/60Hz
5A DC, 10A AC
325 Amps
35%
Price: $2,799.00
  • Advanced AC pulse and AC/DC Standard Pulse
  • Wide range of features including memory, 2T/4T control
  • Adjustable Stick Arc force and Hot Start features
  • 240 1 and 3 phase
PowerTIG 325EXT (480V 3 phase)
  • Advanced AC Pulse
  • 480V 3 phase input
  • CC
GTAW-P/ SMAW
PowerTIG 325EXT 240V 1 phase/480V 3 phase
 480V 3 ph
5A DC/10A AC
325A TIG/ 250 Stick
35%
Price: $2,799.00
  • Advanced AC pulse/AC/DC Standard Pulse
  • 480V 3 phase
Need a TIG?
Don’t need to weld Aluminum?
5 Year Warranty
