Typhoon 230 375LF Cart and 375 Cooler Bundle Package
SKU# TY-230-PC375LF-WC375-BUNDLE
- Unit Weight: 62 lb
- Unit Dimensions: 9.5 in × 26 in × 15 in
The Typhoon 230 bundle package includes the PowerCart 375LF and the PowerCool 375 water cooler. This package gives you everything that normally comes with the Typhoon 230 including the standard accessory package. The cooler included in this package stacks securely under the Typhoon 230 with a smooth, connected look. The cart is designed to hold both the welder and cooler If the cooler isn't needed, it can hold just the welder as well. Adjustable tabs on the cart keep the welder and cooler from sliding around. This package is perfect for professional shops and large fabrication facilities that need a compact water-cooled package. Be sure to add a cover after selecting this package under the "add accessories" option to keep the welder protected when not in use.
Includes:
- Typhoon 230
- Typhoon 230 accessory package
- NOVA PowerCart 375LF
- PowerCool W375 Water Cooler
- 8000 Surge Watts
- Unit is equipped with separate water cooler and wire less foot pedal power outlets
- Do not use the optional water cooler on 120V. Unplug the cooler before using on 120V.
- Do not plug any other device into the water cooler outlet or into the outlet intended for powering the wireless foot pedal.
240V 1 Phase 50/60Hz: 31 A
| Rated Effective Amps (I1Eff) | 120V 1 Phase 50/60Hz: 24 A
240V 1 Phase 50/60Hz: 26 A
| LCD Screen | 5.1 inches
| Type | TFT
| Resolution | 720
| Memory | 30 Programs
| Fan | Temperature Controlled
On-Arc
| TIG Duty Cycle 120V 1 Phase 50/60Hz | 120V 1 Phase 50/60Hz: 70% Duty Cycle @ 40°C at 125A/15V Rated Output
| TIG Duty Cycle 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz: 70% Duty Cycle @ 40°C at 230A/19.2V Rated Output
240V 1 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 190A/17.6V Rated Output
| TIG Output Range 120V 1 Phase 50/60Hz | 120V 1 Phase 50/60Hz TIG Amp AC Output Range: 3 to 125 Amps
120V 1 Phase 50/60Hz TIG Volt AC Output Range: 10.1 to 15 Volts
120V 1 Phase 50/60Hz TIG Amp DC Output Range: 2 to 125 Amps
120V 1 Phase 50/60Hz TIG Volt DC Output Range: 10.1 to 15 Volts
| TIG Output Range 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz TIG Amp AC Output Range: 3 to 230 Amps
240V 1 Phase 50/60Hz TIG Volt AC Output Range: 10.1 to 19.2 Volts
240V 1 Phase 50/60Hz TIG Amp DC Output Range: 2 to 230 Amps
240V 1 Phase 50/60Hz TIG Volt DC Output Range: 10.1 to 19.2 Volts
| Open Circuit Voltage (OCV) | 91V
Lift Start With Remote
| Start Amp Range AC | 3-(125)230A
| Start Amp Range DC | 2-(125)230A
| End Amp Range AC | 3-(125)230A
| End Amp Range DC | 2-(125)230A
| Pre-Flow Time | 0-30 Seconds
| Post-Flow Time | 0-60 Seconds
| Up-Slope Time | 0-30 Seconds
| Down-Slope Time | 0-60 Seconds
| TIG Pulse | AC
| AC Pulse Type | Standard
Advanced
Triangular
Trapezoid
Sine
Double
| DC Pulse Frequency | 0-0-999 Hz
| DC Double Pulse Frequency | 0-9.9 Hz
| Pulse Amperage | 3-100% of Welding Amperage
| AC Frequency | 20-400 Hz
| AC Balance | 5-70% of Positive Electrode
| AC Wave Forms | Square
Soft Square
Triangular
Trapezoid
Sine
| Half-Wave AC Amplitude Function | Yes
| Independent Half-Wave Wave Form Shape Selection | Yes
| Other Functions | Fast Tack (Cold Weld Function)
Spot and Stitch Timer
| Stick Duty Cycle 120V 1 Phase 50/60Hz | 120V 1 Phase 50/60Hz: 70% Duty Cycle @ 40°C at 100A/24V Rated Output
| Stick Duty Cycle 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz: 70% Duty Cycle @ 40°C at 200A/28V Rated Output
| Stick Output Range 120V 1 Phase 50/60Hz | 120V 1 Phase 50/60Hz Stick Amp AC Output Range: 10 to 100 Amps
120V 1 Phase 50/60Hz Stick Volt AC Output Range: 20.4 to 24 Volts
120V 1 Phase 50/60Hz Stick Amp DC Output Range: 10 to 100 Amps
120V 1 Phase 50/60Hz Stick Volt DC Output Range: 20.4 to 24 Volts
| Stick Output Range 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz Stick Amp AC Output Range: 10 to 200 Amps
240V 1 Phase 50/60Hz Stick Volt AC Output Range: 20.4 to 28 Volts
240V 1 Phase 50/60Hz Stick Amp DC Output Range: 10 to 200 Amps
240V 1 Phase 50/60Hz Stick Volt DC Output Range: 20.4 to 28 Volts
| Open Circuit Voltage (OCV) | 79V
| Arc Force | Adjustable
| Anti-Stick Protection | Yes
| Output | AC/DC
| Adjustable AC Balance | Yes
| Adjustable AC Frequency | Yes
| Functions with Remote | Yes
.003" to 7/16"
.003" to 7/16"
.005"- 5/16"
1/16"- 3/16"
- Aerospace
- Rail Car Industry
- Pipe and Structural
- Gunsmithing
- 2 × 2T/4T Torch Switch for TIG welders 7 pin female 15 Ft.
- PowerCool W375 (240V)
- 6 Ft. Input Power Cable with NEMA 6-50 Plug
- TIG Starter Consumable Kit
- 240V to 120V power adapter
