PowerCool W375 (240V)
SKU# PCW375-240
- Unit Weight: 40 lb
- Shipping Weight: 45 lb
- Unit Dimensions: 10 in × 25 in × 11 in
The 240V PowerCool 375 is designed to stack under new-style medium frame Everlast TIG units with the triangular plug connection (IEC 60320-1 C-13) located at the rear of the unit. Starting in 2020 this panel was phased in so, check your unit front and rear panel. The welder will slide in and lock onto the lower water cooler. This includes the TIG and TIG multi-process units with plasma: Power TIG 200DV, 250EX, 315LX, 210EXT, 255EXT, 325EXT, Typhoon 230, 330, PowerPro 164Si, 205Si, 256Si, and 256D. It is recommended for up to 375A welding. The unit can also be placed beside the welder or be installed on a separate shelf over or under the welder. The unit features standard B Type-9mm color-coded quick connect couplings that can be used directly with any Everlast water-cooled TIG torch without any need for adapters. The unit features a copper core heat exchanger, Italian industrial sealed motor and stainless pump with bronze impeller that are designed for years of use. Many competitors use all aluminum piping for heat exchangers and low quality motors and pumps in comparison. This unit features direct shaft drive of fan, pump and motor. There are no belts, or pulleys to wear out or replace. This unit also features an audible warning along with a flashing warning if water flow is interrupted, or falls below the preset flow rate. On some non-Nova/Everlast torches with smaller orifices and cables that restrict flow, the alarm may sound. If so, this is adjustable. Contact Everlast tech support for adjustment instructions.
This unit operates on 240V only. While operating with any Dual-Voltage welder, this unit should be unplugged and removed from service while the welder is operating on 120V because the outlet in the rear of the welder provides only 120V while connected to a 120V outlet. Operating the cooler on 120V may cause damage to the cooler which is not covered under warranty. Some of the listed units for this cooler are dual voltage. Be aware of the voltage you are using. Failure due to operating on 120V will void the warranty and may result in overheating or other damage.
Notice:
Everlast is aware that customers may be using various types of coolant in their PowerCool Water Coolers and with our NOVA or other brand TIG torches. These range from distilled water to Isopropyl alcohol to automotive type anti-freeze to R.V. anti-freeze to “private concoctions.” Since the PowerCool product line was released over 12 years ago we’ve gathered valuable data and gained experience concerning the use of coolants and their impact on both the lifespan of the cooler and the TIG torches themselves. With that said, there are several areas of concern that we look for in a coolant. We have found that most popular alternatives fail to provide satisfactory performance. We have taken our findings and concerns and listed them below as basic elementary requirements needed for best performance and product life.
It is for these reasons, that Everlast is now recommending that customers ONLY use commercial brand coolants designed for use with TIG welders with a rating for use with High Frequency (H.F.). These coolants will usually include statements or information regarding the concerns listed above.
Answer: While we are hesitant to endorse one product like this over the other or demand that any one brand of coolant be used, commercial brands like Praxair, Airgas, Miller, ITW, and Lincoln all provide satisfactory coolants that address the concerns above. There may be others. But extremely low priced coolants, or off brands may not provide the level of protection required. Again, read the label before purchasing and using. Use due diligence in selecting your coolant.
| Input Voltage | 240V
| Input Amps | 1.1A
| Recommended Maximum Output Amperage | 375-400A
| Power Plug Type | IEC 60320-1 C-13
| Cooler Flow Alarm | Yes
| Use With These Units | PowerTIG 210 EXT, 255EXT, 325EXT, 200DV, 250EX, 315LX. Typhoon 230, 330. PowerPro 164Si, 205Si, 256Si, 256D
| Type of Coolant Permissible | TIG low conductivity or MIG coolant depending upon application.
| Pump Type | Vane-Type
| Pump Construction Type | Stainless housing with Bronze impeller
| Pump Output | 1.1 LPM after by pass
| Motor Type | Sealed Industrial
| Heat Exchanger (Radiator) Material Type | Copper core with Aluminum Fins
| Reservoir Size | Approx 2.2 gallons
| Torch Connection Type | Color Coded Quick Connect Coupler
| Important Water Cooler Notes | Do not operate this unit on 120V or while operating dual voltage 120/240V welders on 120V.
