Typhoon 230
SKU# TYP-230
- Unit Weight: 62 lb
- Unit Dimensions: 9.5 in × 26 in × 15 in
Built for professionals who expect serious performance from their equipment, the Everlast Typhoon 230 goes head to head with leading name-brand AC/DC TIG and Stick welders, offering advanced controls and specifications that exceed those of some name brand competitors. With an outstanding 70% duty cycle at maximum TIG output, it delivers the staying power for demanding fabrication, repair and production work. No other welder in it's class comes close to the duty cycle of the Typhoon 230.
The performance capability comes matched with straightforward control. The large 5.1-inch HD LCD presents the main welding functions and parameters on a bright, high-contrast screen, keeping settings visible at a glance. Intuitive controls and a layout that minimizes hidden menus make it easy to set up, fine-tune the arc and get to work.
For aluminum TIG welding, AC amplitude control and separate positive and negative waveform selection give you precise control over arc behavior, heat input and cleaning action while helping manage tungsten wear. Five AC waveforms—Advanced Square, Soft Square, Triangular, Sine and Trapezoidal—expand your options for puddle and bead control across a range of applications. DC pulse waveform shaping brings additional control to steel, stainless and other DC TIG applications, while solid-state HV/HF starting provides noncontact arc starts.
With storage for up to 30 programs and the ability to lock saved settings, the Typhoon 230 also helps maintain consistency when multiple operators share a machine. Established settings stay protected, supporting repeatable setups in production environments and applications that follow a Welding Procedure Specification (WPS).
The Typhoon 230 brings the same attention to performance to Stick welding. AC and DC output, adjustable AC balance and frequency, arc force control (dig) and adjustable hot start give you the flexibility to dial in the arc for the electrode and application. Strong E6010 performance and smooth E7018 operation make it a capable choice for root, fill and cap passes, shop fabrication and field repair. With up to 200 amps of Stick output at a 70% duty cycle, it has the capacity to keep working through demanding jobs.
Dual-voltage 120V/240V operation adds flexibility wherever the work takes you. Power Factor Correction (PFC) helps reduce input current demands and makes efficient use of available power, including compatible generator sources. On-demand fan and water cooler controls activate cooling only when needed, rounding out a professional welding package built to compete on capability, control and everyday usability.
- AC/DC Pulse TIG with AC/DC Stick Output sets the standard for features and adjustability
- 5.1" 720 HD TFT screen allows easy viewing of parameters with high contrast graphics that can be viewed at a distance
- See and adjust all parameters on main screen without the bottle neck created by hidden pop-up menus
- High duty cycle operation at 70% @ maximum 230A output leads the industry
- Independent Amplitude Control on AC allow the Tungsten to last longer and improves penetration
- Single and Double Pulse DC TIG for maximum heat control and steady arc
- Standard AC and Advanced AC TIG (Mixed) Pulse
- Industry leading 5 AC wave forms with ability to assign individual half-wave forms with a total of 15 possible combinations, not including the unique wave form possible when using the AC Advanced Pulse
- Fully adjustable low Amp HV starting with ability to select tungsten size for maximum precision starts
- Remote control with Stick for maximum control with pedal or slider
- Dedicated cooler outlet installed in rear for use with water-cooled torches
- PFC Control for more stable operation on unstable power
- Fan-on-Arc or Temp Control for quieter operation or select full time operation for heavy duty use
- Cooler-on-Arc or full time cooler control when used with optional cooler
- 8000 Surge Watts
- Unit is equipped with separate water cooler and wire less foot pedal power outlets
- Do not use the optional water cooler on 120V. Unplug the cooler before using on 120V.
- Do not plug any other device into the water cooler outlet or into the outlet intended for powering the wireless foot pedal.
240V 1 Phase 50/60Hz: 31 A
| Rated Effective Amps (I1Eff) | 120V 1 Phase 50/60Hz: 24 A
240V 1 Phase 50/60Hz: 26 A
| LCD Screen | 5.1 inches
| Type | TFT
| Resolution | 720
| Memory | 30 Programs
| Fan | Temperature Controlled
On-Arc
| TIG Duty Cycle 120V 1 Phase 50/60Hz | 120V 1 Phase 50/60Hz: 70% Duty Cycle @ 40°C at 125A/15V Rated Output
| TIG Duty Cycle 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz: 70% Duty Cycle @ 40°C at 230A/19.2V Rated Output
240V 1 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 190A/17.6V Rated Output
| TIG Output Range 120V 1 Phase 50/60Hz | 120V 1 Phase 50/60Hz TIG Amp AC Output Range: 3 to 125 Amps
120V 1 Phase 50/60Hz TIG Volt AC Output Range: 10.1 to 15 Volts
120V 1 Phase 50/60Hz TIG Amp DC Output Range: 2 to 125 Amps
120V 1 Phase 50/60Hz TIG Volt DC Output Range: 10.1 to 15 Volts
| TIG Output Range 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz TIG Amp AC Output Range: 3 to 230 Amps
240V 1 Phase 50/60Hz TIG Volt AC Output Range: 10.1 to 19.2 Volts
240V 1 Phase 50/60Hz TIG Amp DC Output Range: 2 to 230 Amps
240V 1 Phase 50/60Hz TIG Volt DC Output Range: 10.1 to 19.2 Volts
| Open Circuit Voltage (OCV) | 91V
Lift Start With Remote
| Start Amp Range AC | 3-(125)230A
| Start Amp Range DC | 2-(125)230A
| End Amp Range AC | 3-(125)230A
| End Amp Range DC | 2-(125)230A
| Pre-Flow Time | 0-30 Seconds
| Post-Flow Time | 0-60 Seconds
| Up-Slope Time | 0-30 Seconds
| Down-Slope Time | 0-60 Seconds
| TIG Pulse | AC
| AC Pulse Type | Standard
Advanced
Triangular
Trapezoid
Sine
Double
| DC Pulse Frequency | 0-0-999 Hz
| DC Double Pulse Frequency | 0-9.9 Hz
| Pulse Amperage | 3-100% of Welding Amperage
| AC Frequency | 20-400 Hz
| AC Balance | 5-70% of Positive Electrode
| AC Wave Forms | Square
Soft Square
Triangular
Trapezoid
Sine
| Half-Wave AC Amplitude Function | Yes
| Independent Half-Wave Wave Form Shape Selection | Yes
| Other Functions | Fast Tack (Cold Weld Function)
Spot and Stitch Timer
| Stick Duty Cycle 120V 1 Phase 50/60Hz | 120V 1 Phase 50/60Hz: 70% Duty Cycle @ 40°C at 100A/24V Rated Output
| Stick Duty Cycle 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz: 70% Duty Cycle @ 40°C at 200A/28V Rated Output
| Stick Output Range 120V 1 Phase 50/60Hz | 120V 1 Phase 50/60Hz Stick Amp AC Output Range: 10 to 100 Amps
120V 1 Phase 50/60Hz Stick Volt AC Output Range: 20.4 to 24 Volts
120V 1 Phase 50/60Hz Stick Amp DC Output Range: 10 to 100 Amps
120V 1 Phase 50/60Hz Stick Volt DC Output Range: 20.4 to 24 Volts
| Stick Output Range 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz Stick Amp AC Output Range: 10 to 200 Amps
240V 1 Phase 50/60Hz Stick Volt AC Output Range: 20.4 to 28 Volts
240V 1 Phase 50/60Hz Stick Amp DC Output Range: 10 to 200 Amps
240V 1 Phase 50/60Hz Stick Volt DC Output Range: 20.4 to 28 Volts
| Open Circuit Voltage (OCV) | 79V
| Arc Force | Adjustable
| Anti-Stick Protection | Yes
| Output | AC/DC
| Adjustable AC Balance | Yes
| Adjustable AC Frequency | Yes
| Functions with Remote | Yes
.003" to 3/8"
.003" to 3/8"
.005"- 5/16"
1/16"- 3/16"
- Aerospace
- Rail Car Industry
- Pipe and Structural
- Gunsmithing
- 2 × 2T/4T Torch Switch for TIG welders 7 pin female 15 Ft.
- 6 Ft. Input Power Cable with NEMA 6-50 Plug
- TIG Starter Consumable Kit
- 240V to 120V power adapter
