Typhoon 330 375LF Cart, W375 Cooler and Wireless Pedal Bundle Package
SKU# TYP-330-375LF-W375-NVAFT06-BUNDLE-5
- Unit Weight: 62 lb
- Unit Dimensions: 9.5 in × 26 in × 15 in
This Typhoon 330 bundle package includes the PowerCart 375LF and the PowerCool 375 water cooler and NOVA wireless foot pedal. This complete package gives you everything that normally comes with the Typhoon including the standard accessory package. The cooler included in this package stacks securely under the Typhoon 330 with a smooth, connected look. The cart is designed to hold both the welder and cooler. If the cooler isn't needed, it can hold just the welder as well. Adjustable tabs on the cart keep the welder and cooler from sliding around. The NOVA wireless foot pedal is also included and will plug into the rear of the unit for power. The foot pedal is good for up to 300 ft away and can be used with other NOVA pedals in the same area with no cross-talk. This professional package is perfect for small shops and fabrication facilities that need a compact water-cooled package. Be sure to add a cover after selecting this package under the "add accessories" option to keep the welder protected when not in use.
Includes:
- Typhoon 330
- Typhoon 330 accessory package
- NOVA PowerCart 375LF
- PowerCool W375 Water Cooler
- NOVA Wireless TIG Foot Pedal
- 15,500 Surge Watts
- Unit is equipped with separate water cooler and wire less foot pedal power outlets.
- Do not plug any other device into the water cooler outlet or into the outlet intended for powering the wireless foot pedal.
240V 3 Phase 50/60Hz
| Max Inrush Amps (I1Max) | 240V 1 Phase 50/60Hz: 63 A
240V 3 Phase 50/60Hz: 31 A
240V 3 Phase 50/60Hz: 20 A
| LCD Screen | 5.1 inches
| Type | TFT
| Resolution | 720
| Memory | 30 Programs
| Fan | Temperature Controlled
On-Arc
| TIG Duty Cycle 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz: 40% Duty Cycle @ 40°C at 330A/23.2V Rated Output
240V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 270A/20.8V Rated Output
240V 1 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 210A/18.4V Rated Output
| TIG Duty Cycle 240V 3 Phase 50/60Hz | 240V 3 Phase 50/60Hz: 40% Duty Cycle @ 40°C at 330A/23.2V Rated Output
240V 3 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 270A/20.8V Rated Output
240V 3 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 210A/18.4V Rated Output
| TIG Output Range 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz TIG Amp AC Output Range: 3 to 330 Amps
240V 1 Phase 50/60Hz TIG Volt AC Output Range: 10.1 to 23.2 Volts
240V 1 Phase 50/60Hz TIG Amp DC Output Range: 2 to 330 Amps
240V 1 Phase 50/60Hz TIG Volt DC Output Range: 10.1 to 23.2 Volts
| TIG Output Range 240V 3 Phase 50/60Hz | 240V 3 Phase 50/60Hz TIG Amp AC Output Range: 3 to 330 Amps
240V 3 Phase 50/60Hz TIG Volt AC Output Range: 10.1 to 23.2 Volts
240V 3 Phase 50/60Hz TIG Amp DC Output Range: 2 to 330 Amps
240V 3 Phase 50/60Hz TIG Volt DC Output Range: 10.1 to 23.2 Volts
| Open Circuit Voltage (OCV) | 83V
Lift Start With Remote
| Start Amp Range AC | 3-330A
| Start Amp Range DC | 2-330A
| End Amp Range AC | 3-330A
| End Amp Range DC | 2-300A
| Pre-Flow Time | 0-30 Seconds
| Post-Flow Time | 0-60 Seconds
| Up-Slope Time | 0-30 Seconds
| Down-Slope Time | 0-60 Seconds
| TIG Pulse | AC
| AC Pulse Type | Standard
Advanced
Triangular
Trapezoid
Sine
Double
| DC Pulse Frequency | 0-0-999 Hz
| DC Double Pulse Frequency | 0-9.9 Hz
| Pulse Amperage | 3-100% of Welding Amperage
| AC Frequency | 20-400 Hz
| AC Balance | 5-70% of Positive Electrode
| AC Wave Forms | Square
Soft Square
Triangular
Trapezoid
Sine
| Half-Wave AC Amplitude Function | Yes
| Independent Half-Wave Wave Form Shape Selection | Yes
| Other Functions | Fast Tack (Cold Weld Function)
Spot and Stitch Timer
| Stick Duty Cycle 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz: 40% Duty Cycle @ 40°C at 275A/31V Rated Output
240V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 220A/28.8V Rated Output
240V 1 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 170A/26.8V Rated Output
| Stick Duty Cycle 240V 3 Phase 50/60Hz | 240V 3 Phase 50/60Hz: 40% Duty Cycle @ 40°C at 275A/31V Rated Output
240V 3 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 220A/28.8V Rated Output
240V 3 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 170A/26.8V Rated Output
| Stick Output Range 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz Stick Amp AC Output Range: 10 to 275 Amps
240V 1 Phase 50/60Hz Stick Volt AC Output Range: 20.4 to 31 Volts
240V 1 Phase 50/60Hz Stick Amp DC Output Range: 10 to 275 Amps
240V 1 Phase 50/60Hz Stick Volt DC Output Range: 20.4 to 31 Volts
| Stick Output Range 240V 3 Phase 50/60Hz | 240V 3 Phase 50/60Hz Stick Amp AC Output Range: 10 to 275 Amps
240V 3 Phase 50/60Hz Stick Volt AC Output Range: 20.4 to 31 Volts
240V 3 Phase 50/60Hz Stick Amp DC Output Range: 10 to 275 Amps
240V 3 Phase 50/60Hz Stick Volt DC Output Range: 20.4 to 31 Volts
| Open Circuit Voltage (OCV) | 76V
| Arc Force | Adjustable
| Anti-Stick Protection | Yes
| Output | AC/DC
| Adjustable AC Balance | Yes
| Adjustable AC Frequency | Yes
| Functions with Remote | Yes
.003" to 1/2"
.003" to 1/2"
.005"- 7/16"
1/16"- 1/4"
- Aerospace
- Rail Car Industry
- Pipe and Structural
- Gunsmithing
- 2 × 2T/4T Torch Switch for TIG welders 7 pin female 15 Ft.
- PowerCool W375 (240V)
- NOVA™ Wireless Pedal For Everlast TIGs With Large 7 Pin Connector
- 6 Ft. Input Power Cable with NEMA 6-50 Plug
- TIG Starter Consumable Kit
