PowerTIG 250EX Water Cooler Package, view 1
Power TIG 250EX Front View
Accessory Package View
SKU# PT-250EX-PCW375
Analog AC/DC
$2,238.00
$1,865.00
Save - $373.00
Analog AC/DC
  • Unit Weight: 105 lb
  • Shipping Weight: 114.78 lb
This combination package includes the PowerTIG 250EX and PowerCool W375 Water Cooler, designed to pair together as an integrated system.
The PowerTIG 250EX stacks securely on top of the PowerCool W375 using a system of slide-on interlocking tabs. For a more permanent installation, the two units can also be fastened together using the side-panel screws and bracket, keeping them firmly connected during use and transport.
The 240V PowerCool W375 plugs directly into a dedicated power outlet on the rear of the PowerTIG 250EX, providing a clean and convenient installation without the need for a separate 240V wall outlet.
This package also includes all of the standard accessories supplied with the PowerTIG 250EX.
Includes:
  1. PowerTIG 250EX
  2. Accessory Package
  3. Power Cool W375 Water Cooler
10,500 Watts Surge Rating
240V 3 Phase 50/60Hz
240V 1 Phase 50/60Hz: 40 A
240V 3 Phase 50/60Hz: 21 A
240V 1 Phase 50/60Hz: 32 A
240V 3 Phase 50/60Hz: 16 A
On-Arc
Cooler Control
Runs Continuously
240V 3 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 250A/20V Rated Output
240V 3 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 250A/18V Rated Output
240V 1 Phase 50/60Hz TIG Amp AC Output Range: 5 to 250 Amps
240V 1 Phase 50/60Hz TIG Volt AC Output Range: 10.2 to 18 Volts
240V 1 Phase 50/60Hz TIG Amp DC Output Range: 5 to 250 Amps
240V 3 Phase 50/60Hz TIG Amp AC Output Range: 5 to 250 Amps
240V 3 Phase 50/60Hz TIG Volt AC Output Range: 10.2 to 18 Volts
240V 3 Phase 50/60Hz TIG Amp DC Output Range: 5 to 250 Amps
240V 3 Phase 50/60Hz TIG Volt DC Output Range: 10.2 to 18 Volts
85V
TIG Start Type
Lift Start With Remote
Start Amp Range AC
5-250A
Start Amp Range DC
5-250A
End Amp Range AC
5-250A
End Amp Range DC
5-250A
0-10 Seconds
0-25 Seconds
0-10 Seconds
0-25 Seconds
TIG Pulse
AC
AC Pulse Type
DC TIG Pulse Wave Shape
Square
DC Pulse Frequency
0-500 Hz
AC Pulse Frequency
0-500 Hz
10-90%
Pulse Amperage
5-95% of Welding Amperage
AC Frequency
20-250 Hz
AC Balance
10-90% of Positive Electrode
AC Wave Forms
Square
.007" to 1/2"
.007" to 1/2"
.008"- 3/8"
1/16"- 5/32"
  • Rail Car Industry
  • Pipe and Structural
  • Gunsmithing
Product Videos
