PowerPlasma 102i CNC Package, view 1
PowerPlasma 102i CNC Package, view 2
PowerPlasma 102i CNC Package, view 3
PowerPlasma 102i CNC Package, view 4
SKU# PP-102I-240-1-3-CNC
Hand or CNC Cutting
$2,399.00
$2,149.00
Save - $250.00
Hand or CNC Cutting
  • Unit Weight: 58 lb
  • Shipping Weight: 67 lb
The PowerPlasma 102i CNC Package is designed for industrial cutting with CNC plasma tables, automated track torches, and pipe bevelers. It accepts 240V one-phase or 240V three-phase input and includes a PTM 100 machine torch for high-quality cuts in material approximately 7/8 to 1 inch thick.
Optional consumables let you match the cutting setup to the material and help reduce kerf width on thinner gauges. A hand-cutting torch is not included. To add one, select it under Add Accessories after placing the unit in your cart.
  1. 240V 1 or 240V 3 phase input power
  2. CNC Port Built in
  3. Blow-Back Style, Pilot Arc PTM 100 Machine Torch
  7. Gouge function
Generator Requirements*:
  2. 19,500 Surge Watts 1 phase 240V
  3. 16,500 Surge Watts 3 phase 240V
Important Note:
240V 3 Phase 50/60Hz
240V 1 Phase 50/60Hz: 74 A
240V 3 Phase 50/60Hz: 37 A
240V 1 Phase 50/60Hz: 59 A
240V 3 Phase 50/60Hz: 30 A
240V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 100A/120V Rated Output
240V 1 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 80A/112V Rated Output
Plasma Duty Cycle 240V 3 Phase 50/60Hz
240V 3 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 100A/120V Rated Output
340V
Arc Start Type
Blowback, Piston Type
Torch Type
CNC Capable/Ready
Yes, with optional Torch
Gouging Capable
Gouging Duties
Heavy
Drag Cutting
Post Flow Timer
Adjustable
Parts-In-Place Safety Cut Out
Recommended Flow Rate (Air)
9 CFH @ 90 PSI
Maximum Supply Pressure
90 PSI
Compressor Built In
60 Gallon
65-75
Remote
Tip Saver Function
Location of CNC Port
Rear
CNC Port Type
WEiPu SP21 12 pin
Torch Connector Type
Central Euro
  1. Up to 1 1/4 " daily use
  2. Up to 1 5/16 " clean cut
  3. Up to 1 1/2" severance cut
  4. Pierce up to 3/4"
Units are supplied with a starter set of consumables intended primarily for cutting in the 90–100 amp range. While there is effectively no practical minimum material thickness that can be cut, standard higher-amperage tips may produce an unnecessarily wide kerf on very thin material. For best results on lighter gauges, use a consumable with a smaller orifice matched to the required cutting amperage.
  1. Up to 7/8" daily use
  2. Up to 1 1/8" clean cut (edge start)
  3. Pierce up to 3/4"
  • Aerospace
  • Pipe and Structural
