PowerPlasma 102i 240V/480V 3 Ph CNC Package
SKU# PP-102I-240-480-CNC
- Unit Weight: 58 lb
- Shipping Weight: 67 lb
- Unit Dimensions: 9.75 in × 25 in × 15 in
The PowerPlasma 102i is a professional plasma cutter that delivers quality cutting performance for professional shops that regularly cut 1" and greater material by hand. This unit can actually severe much thicker, but it is ready to tackle hand cutting chores anywhere thick plate is found. This unit only operates with 240V 3 phase or 480V 3 phase input.
- 240V 3 or 480V 3 phase input power
- CNC Port Built in
- Blow-Back Style, Pilot Arc PTM 100 Machine Cutting Torch
- Parts in Place safety cut out
- Low air pressure safety cut out
- Gouge function
Generator Requirements*:
- 18,500 Surge Watts 3 phase 240V
- 17,000 Surge Watts 3 Phase 480V
Important Note:
| Voltage/Phase | 240V 3 Phase 50/60Hz
480V 3 Phase 50/60Hz
| Max Inrush Amps (I1Max) | 240V 3 Phase 50/60Hz: 40 A
480V 3 Phase 50/60Hz: 18 A
| Rated Effective Amps (I1Eff) | 240V 3 Phase 50/60Hz: 32 A
480V 3 Phase 50/60Hz: 15 A
| LCD Screen | No
| Memory | No
| Plasma Duty Cycle 240V 3 Phase 50/60Hz | 240V 3 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 100A/120V Rated Output
| Plasma Duty Cycle 480V 3 Phase 50/60Hz | 480V 3 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 100A/120V Rated Output
480V 3 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 80A/112V Rated Output
| Open Circuit Voltage (OCV) | 310V
| Torch Type | PTM 100 Machine Torch
| CNC Capable/Ready | Yes, with optional Torch
| Gouging Duties | Heavy
| Recommended Flow Rate (Air) | 9 CFH @ 90 PSI
| Compressor Built In | No
| Recommended Minimum Compressor Size | 60 Gallon
| Remote | 2T
| Tip Saver Function | Yes
| Location of CNC Port | Rear
- Up to 1 1/4 " daily use
- Up to 1 5/16 " clean cut
- Up to 1 1/2" severance cut
- Pierce up to 3/4"
Units are supplied with a starter set of consumables intended primarily for cutting in the 90–100 amp range. While there is effectively no practical minimum material thickness that can be cut, standard higher-amperage tips may produce an unnecessarily wide kerf on very thin material. For best results on lighter gauges, use a consumable with a smaller orifice matched to the required cutting amperage.
- Up to 7/8" daily use
- Up to 1 1/8" clean cut (edge start)
- Pierce up to 3/4"
- Aerospace
- Pipe and Structural
- AW3000 Plasma Cutter Regulator for PowerPlasma 82i and 102i
- PTM-100 CNC/Machine Torch Blow Back Start 25 Ft. Central Connector
- WEiPu SP21 CNC Connector 12 Pin
- Starter consumable kit
- 6.5 Ft. Power input cable (No Plug)
