PowerCart 301 HD Welding Cart with Single Cylinder Capacity, view 1
PowerCart 301 HD Welding Cart with Single Cylinder Capacity, view 2
SKU# PC-301-ML
Welding Carts (See Also Welding Tables)
$329.00
SKU# PC-301-ML
  • Unit Weight: 68 lb
  • Shipping Weight: 71.99 lb
  • Unit Dimensions: 15 in × 41.5 in × 45.78 in
The PowerCart 301 is designed to be a heavy duty yet nimble welding cart that does it job with simplicity and functionality. Don't let the simple appearance fool you. It is a workhorse and will carry the load and will hold up to a 9" full size cylinder. The simple hose and cable hangers and front grab bar allow the unit to accommodate multiple torches, cables and work clamps.
Rated at 400 lbs, this cart is overbuilt for it's payload. It is designed to fit current large frame redesigned 2025 and newer model welders with three handle possibilities (Front / Central / Rear) that are 400A and under. This includes the PowerTIG 400EXT, Hurricane 220 MTS-C, Lightning MTS 225, Lightning MTS 275 with the PowerCool W401 water coolers all with the updated design. For older models with a single handle or different configuration from the ones pictured above, see the PowerCart 300.
The cart is designed to capture and fix the cooler to the cart without moving or sliding off. When the welder is stacked on top and locked into the cooler mating surface, the top bar on the unit clamps down to the top and keeps it from toppling off the cart. The low profile design helps keep a compact shop profile so that it rolls out of the way and stores without much wasted space. The large wheels combined with heavy duty, roller-type bearing allow the cart to glide over most shop surfaces with ease.
Note: This cart also will fit the Cyclone 253DPi, Cyclone 263Pi, Cyclone 312i (excluding 312i PRO) to use without water coolers. This design is specifically made for the Everlast large frame redesigned 2025 model units to use it with installed on the units three top handles. This cart will hold one gas cylinder. Support Seat for external wire feeders is not included. This cart WILL NOT fit smaller units or large frame (up to late 2024 model) year units with one top central handle. For those model units please see PowerCart 300 where large (up to late 2024 model) year unit is shown as well.
Maximum Gross Weight Capacity
400 lbs.
Maximum Cylinder Size Supported
9"
Casters/Wheels
Yes, 2 Swivel and 2 Straight
