Thunder 255 MTS, view 1
Thunder 255 MTS, view 2
Thunder 255 MTS, view 3
Thunder 255 MTS, view 4
SKU# THUN-255-DV
Pulse MIG
$1,999.00
$1,699.00
Save - $300.00
Pulse MIG
SKU# THUN-255-DV
  • Unit Weight: 89 lb
  • Shipping Weight: 113 lb
  • Unit Dimensions: 11.5 in × 27.5 in × 17 in
Built for professionals, the Everlast Thunder 255 is a versatile workhorse ready for daily fabrication, production welding, and work shop repairs. With MIG, DC TIG, and Stick capabilities in one machine, it gives you the flexibility to tackle a wide range of jobs without crowding your shop with extra equipment. Its digitally controlled inverter delivers a stable, responsive arc, with extensive adjustments to fine-tune performance for the work at hand.
The built-in wire feeder supports short-circuit MIG, conventional spray transfer, and single-pulse spray MIG, giving you more control over heat, spatter, and productivity. Dedicated settings for self-shielded and gas-shielded flux-core wire expand its usefulness for demanding applications.
The DC TIG mode offers a smooth stable arc for welding steel, stainless and many other metals. With pulse, the control and improvement in weld capability is significant. The only thing that will limit you with this TIG setup is that it is DC and will not weld aluminum or Magnesium. However with the Pulse MIG function, the unit can be equipped with either a spool gun or a push-pull gun to weld day in and day out with Aluminum wire. Of course, the Pulse MIG itself works well with both steel and stainless wires. Anytime heat control is needed without compromising penetration, the Pulse MIG function will be there to provide spatter free performance.
  1. Smooth, spatter-free single pulse MIG
  2. Gas Shielded Flux-Cored Performance for Industrial and Structural applications
  3. DC Pulse TIG for structural and pipe welding
  4. 5.1" HD screen for easy viewing of controls and parameters
  5. Run-in function for improved arc starting
  6. Cart and stackable cooler available for a complete package
  7. 12" or 8" Wire spool capacity
  8. Heavy-duty 4 Roller drive system for smooth feeding with standard guns and improved push-pull gun operation
  9. Supports spool gun or push-pull gun operation
  10. Stick welding function with E-6010 (Cellulosic) capability
  11. Save up to 30 programs
  2. Surge Watts 12,500
240V 1 Phase 50/60Hz: 48 A
240V 1 Phase 50/60Hz: 38 A
5.1 inches
Type
TFT
Resolution
720
30 Programs
Cooler Control
Runs Continuously
70V
Start Wire Feed Speed
Adjustable
End Wire Feed Speed
Adjustable
MIG Hot Start
Adjustable
MIG Hot Start Duration
Adjustable
MIG Crater Fill (End Fill)
Adjustable
Adjustable
0-10 Seconds
0-30 Seconds
0-1 Seconds
0-1 Seconds
2T SP
4T SP
MIG Pulse
Single
MIG Pulse Pinch Effect
MIG Pulse Operation
Synergic
Spool Sizes
8”
12”
.035”
V- Groove
4
PowerSet Simplified Pro Setup
Water Cooler Capable
Spool Gun Capable
Push Pull Gun Capable
MIG Functions
Wire Jog
Arc Trim (Pulse)
Run-In
Spot
Stitch
Wire Feed Speed
600 IPM
Torch/Gun
North 36 Series 10 Ft.
24 gauge to 3/8"
20 gauge to 3/8"
1/8"- 3/8""
*Capability varies based on skill, weldment size and general welding knowledge. The maximum limit is a practical recommended single pass limit based on the industry standard of performing thicker welds with multiple passes. Aluminum range is limited due to the spray process required for non-pulse MIGs to make a proper weld. Short circuit can be accomplished on thinner metals, but welds may not be structurally sound. For best results using the standard gun feeding with red polymer liner and U-groove drive rolls, use .040, .047 (3/64") wire.
Common Recommended Metal Types and capabilities For DC TIG**:
.015" to 5/16"
.015" to 5/16"
Not to be welded with DC TIG.
  • Rail Car Industry
  • Pipe and Structural
Downloads
