PowerTIG 325EXT, view 1
PowerTIG 325EXT, view 2
PowerTIG 325EXT, view 3
PowerTIG 325EXT, view 4
PowerTIG 325EXT
Digital AC/DC
SKU# PT-325EXT-240
  • Unit Weight: 64 lb
  • Unit Dimensions: 9.25 in × 25 in × 15 in
PowerTIG 325EXT
Built for professional fabrication, production and repair, the PowerTIG 325EXT combines serious welding power with precise control. Its digitally controlled IGBT inverter delivers up to 320A of AC/DC TIG output at a 35% duty cycle, with 240V single- or three-phase operation for a wide range of shop applications.
For aluminum welding, four AC waveforms—Advanced Square, Soft Square, Triangular and Sine—combine with adjustable AC balance and frequency up to 250 Hz to tailor the arc to the job. Advanced AC Pulse increases penetration on thicker aluminum, while standard pulse up to 500 Hz in DC and 250 Hz in AC helps manage heat on thinner materials.
Straightforward controls, Easy Start Up modes and programmable memory simplify setup and repeat work. Electronic HV arc starting eliminates traditional point-gap maintenance, while Fan-On-Demand automatically manages cooling during and after welding.
The 325EXT also delivers up to 250A of DC Stick output, with adjustable hot start and arc force to fine-tune starting and welding performance. From detailed TIG work to heavier fabrication and everyday repairs, it gives professionals the power and versatility to take on more.
Key Features
  1. Operate on either 220/ 240V 1 phase or 220/240V 3 phase for versatile performance options
  2. 5A DC Start and 10A AC Start for excellent arc starts on thinner materials
  3. Smooth, stable arc in TIG delivers a higher quality weld
  4. Solid state HV Start removes the issue of point gap maintenance for traditional HF starting
  5. 60% Duty cycle at maximum ouput, regardless of phase the unit is operated on extends operation times for true industrial settings
  6. Advanced AC pulse increases range of AC TIG performance by using a mixed/hybrid AC and DC negative pulse for maximum penetration
  7. 4 Adjustable AC Wave Forms: Advanced Square, Soft Square, Triangular and Sine Wave for improved Aluminum welding control
  8. Fan-on-arc for quieter operation
  2. 15,500 Surge Watts on 1 phase 240V
  1. E6010 mode operates best with a short arc
  2. TIG lift start requires a remote to start arc. It is not a live lift function.
240V 3 Phase 50/60Hz
240V 1 Phase 50/60Hz: 60 A
240V 3 Phase 50/60Hz: 30 A
240V 1 Phase 50/60Hz: 36 A
240V 3 Phase 50/60Hz: 18 A
21S
9 Programs
On-Arc
Cooler Control
Runs Continuously
240V 1 Phase 50/60Hz: 35% Duty Cycle @ 40°C at 320A/22.8V Rated Output
240V 3 Phase 50/60Hz: 35% Duty Cycle @ 40°C at 320A/28V Rated Output
240V 3 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 250A/20V Rated Output
240V 3 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 200A/18V Rated Output
240V 1 Phase 50/60Hz TIG Amp AC Output Range: 10 to 320 Amps
240V 1 Phase 50/60Hz TIG Volt AC Output Range: 10.4 to 22.8 Volts
240V 1 Phase 50/60Hz TIG Amp DC Output Range: 5 to 320 Amps
240V 1 Phase 50/60Hz TIG Volt DC Output Range: 10.2 to 22.8 Volts
240V 3 Phase 50/60Hz TIG Amp AC Output Range: 10 to 320 Amps
240V 3 Phase 50/60Hz TIG Volt AC Output Range: 10.4 to 22.8 Volts
240V 3 Phase 50/60Hz TIG Amp DC Output Range: 5 to 320 Amps
240V 3 Phase 50/60Hz TIG Volt DC Output Range: 10.2 to 22.8 Volts
88V
TIG Start Type
Lift Start With Remote
Start Amp Range AC
10-320A
Start Amp Range DC
5-320A
End Amp Range AC
10-320A
End Amp Range DC
5-320A
0-25 Seconds
0-50 Seconds
0-25 Seconds
0-25 Seconds
TIG Pulse
AC
AC Pulse Type
Advanced
DC TIG Pulse Wave Shape
Square
DC Pulse Frequency
0-500 Hz
AC Pulse Frequency
0-250 Hz
AC Advanced Pulse Frequency
0-9.9 Hz
5-95%
Pulse Amperage
5-100% of Welding Amperage
AC Frequency
20-250 Hz
AC Balance
5-90% of Positive Electrode
AC Wave Forms
Square
Soft Square
Triangular
Sine
.007" to 1/2"
.007" to 1/2"
.008"- 3/8"
1/16"- 5/32"
  • Aerospace
  • Rail Car Industry
Downloads
