PowerTIG 315 LX
SKU# PT-315LX
- Unit Weight: 72 lb
- Shipping Weight: 87 lb
- Unit Dimensions: 9.5 in × 25 in × 15 in
The PowerTIG 315 LX is designed for the serious professional welder who wants to set up the machine and get to work without navigating complicated menus or unnecessary settings. Its traditional knob-style controls provide a familiar, intuitive interface while offering the performance and adjustability required for demanding commercial and industrial applications.
Built with production environments in mind, the PowerTIG 315 LX is well suited for repetitive welding operations where consistency, reliability, and ease of setup are essential. Once the proper parameters are established, operators can focus on producing the same high-quality welds part after part, shift after shift.
For aluminum welding, adjustable AC Balance and AC Frequency controls provide the flexibility needed to fine-tune arc characteristics, cleaning action, penetration, and overall weld performance. For even greater control over heat input and weld appearance, the built-in pulse function operates in both AC and DC TIG modes.
Straightforward to operate, powerful, and built for dependable professional service, the PowerTIG 315 LX is a true production-ready workhorse designed to deliver the pay check.
- 13,500 Surge Watts
- Not for use with E6010 and most cellulosic rods
- E6011 use is permissible
| Max Inrush Amps (I1Max) | 240V 1 Phase 50/60Hz: 53 A
| Rated Effective Amps (I1Eff) | 240V 1 Phase 50/60Hz: 31 A
| LCD Screen | No
| Memory | No
| Fan | On-Arc
| TIG Duty Cycle 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 315A/22.6V Rated Output
| TIG Output Range 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz TIG Amp AC Output Range: 20 to 315 Amps
240V 1 Phase 50/60Hz TIG Volt AC Output Range: 10.8 to 22.6 Volts
240V 1 Phase 50/60Hz TIG Amp DC Output Range: 5 to 315 Amps
240V 1 Phase 50/60Hz TIG Volt DC Output Range: 10.2 to 22.6 Volts
| Start Amp Range AC | 20-315A
| Start Amp Range DC | 5-315A
| End Amp Range AC | 20-315A
| End Amp Range DC | 5-315A
| Up-Slope Time | 0-15 Seconds
| Down-Slope Time | 0-30 Seconds
| TIG Pulse | AC
| AC Pulse Type | Standard
| DC Pulse Frequency | 0-750 Hz
| AC Frequency | 20-250 Hz
| AC Balance | 20-80% of Positive Electrode
| AC Wave Forms | Square
| Stick Duty Cycle 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz: 35% Duty Cycle @ 40°C at 250A/30V Rated Output
| Stick Output Range 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz Stick Amp DC Output Range: 20 to 250 Amps
240V 1 Phase 50/60Hz Stick Volt DC Output Range: 20.8 to 30 Volts
| Hot Start Time | Fixed
| Arc Force | Adjustable
| Anti-Stick Protection | No
| Functions with Remote | No
.015" to 1/2"
.015" to 1/2"
.030"- 1/2"
*Capability varies based on skill, weldment size, joint prep and general welding knowledge. The maximum limit is a practical recommended single pass limit based on the industry standard of performing thicker welds with multiple passes on properly prepared joints. A multi-pass weld may be required to achieve the thickest maximum weld. All figures are approximate.
1/16"- 3/16"
- Rail Car Industry
- Production
- 2T/4T Torch Switch for TIG welders 7 pin female 15 Ft.
- Consumable Starter Kit
- 6 ft. Power Input Cable with NEMA 6-50 Plug (Plug not included on Optional 3 phase units)
Downloads
