PowerTIG 255EXT, view 1
PowerTIG 255EXT, view 2
255EXT TIG
Side View PowerTIG 255EXT
Rear View 255EXT
255EXT TIG
Rear View 255EXT
SKU# PT-255EXT
PowerTIG 255EXT
Digital AC/DC
$2,499.00
$1,875.00
Save - $624.00
PowerTIG 255EXT
Digital AC/DC
SKU# PT-255EXT
  • Unit Weight: 62 lb
  • Unit Dimensions: 9.25 in × 25 in × 15 in
PowerTIG 255EXT
Built for professional shops and growing businesses, the PowerTIG 255EXT combines advanced AC/DC Pulse TIG capability, versatile Stick performance and exceptional value. Digital microprocessor control puts programmable memory, selectable waveforms and precise pulse adjustments at your fingertips, while two Easy Start Up modes simplify setup. Advanced AC Pulse expands your capabilities on aluminum, helping improve penetration on thicker sections and maintain control on thin material.
Adjustable hot start time, hot start intensity and arc force let you fine-tune Stick performance for demanding applications with E6010 or E7018 electrodes. For TIG work, a spot weld timer helps produce consistent tacks and spot welds on sheet metal, while a dedicated gas purge button lets you set shielding gas flow without starting an arc.
Designed for long service life and easier maintenance, the 255EXT features modular construction and digital inverter design with components from established name-brand manufacturers to simplify diagnosis and repair. The welder also supports 120V or 240V operation, giving you greater flexibility in the shop or on the job—with up to 150A TIG and 120A Stick output when operating on 120V.
Key Features
  1. 120/240V operation for go anywhere performance
  2. Low AC and DC TIG Starting Amps
  3. Smooth, stable arc in TIG
  4. Solid state HV Start removes the issue of point gap maintenance for traditional HF starting
  5. 60% Duty cycle at maximum ouput extends operation times for true industrial settings
  6. Advanced AC pulse increases range of AC TIG performance by using a mixed/hybrid AC and DC negative pulse for maximum penetration
  7. 4 Adjustable AC Wave Forms: Advanced Square, Soft Square, Triangular and Sine Wave for improved Aluminum welding control
  8. Fan-on-arc for quieter operation
  2. 9500 Surge Watts
  1. E6010 mode operates best with a short arc
  2. TIG lift start requires a remote to start arc. It is not a live lift function.
120V 1 Phase 50/60Hz
120V 1 Phase 50/60Hz: 38 A
240V 1 Phase 50/60Hz: 38 A
120V 1 Phase 50/60Hz: 30 A
240V 1 Phase 50/60Hz: 30 A
9 Programs
On-Arc
Cooler Control
Runs Continuously
120V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 150A/16V Rated Output
120V 1 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 120A/14.8V Rated Output
120V 1 Phase 50/60Hz TIG Amp AC Output Range: 5 to 125 Amps
120V 1 Phase 50/60Hz TIG Volt AC Output Range: 10.2 to 15 Volts
120V 1 Phase 50/60Hz TIG Amp DC Output Range: 3 to 125 Amps
120V 1 Phase 50/60Hz TIG Volt DC Output Range: 10.1 to 15 Volts
240V 1 Phase 50/60Hz TIG Amp AC Output Range: 5 to 250 Amps
240V 1 Phase 50/60Hz TIG Volt AC Output Range: 10.2 to 20 Volts
240V 1 Phase 50/60Hz TIG Amp DC Output Range: 3 to 250 Amps
240V 1 Phase 50/60Hz TIG Volt DC Output Range: 10.1 to 20 Volts
90V
TIG Start Type
Lift Start With Remote
Start Amp Range AC
5-(150)250A
Start Amp Range DC
3-(150)250A
End Amp Range AC
5-(150)250A
End Amp Range DC
3-(150)250A
0-25 Seconds
0-50 Seconds
0-25 Seconds
0-25 Seconds
TIG Pulse
AC
AC Pulse Type
Advanced
DC TIG Pulse Wave Shape
Square
DC Pulse Frequency
0-500 Hz
AC Pulse Frequency
0-250 Hz
AC Advanced Pulse Frequency
0-9.9 Hz
5-95%
Pulse Amperage
5-100% of Welding Amperage
AC Frequency
20-250 Hz
AC Balance
5-90% of Positive Electrode
AC Wave Forms
Square
Soft Square
Triangular
Sine
.007" to 1/2"
.007" to 1/2"
.008"- 3/8"
1/16"- 5/32"
  • Aerospace
  • Rail Car Industry
Downloads
