PowerPro 256Si, view 1
PowerPro 256Si, view 2
PowerPro 256Si, view 3
SKU# PP-256SI
PowerPro 256Si
Analog AC/DC
$1,999.00
$1,599.00
Save - $400.00
PowerPro 256Si
Analog AC/DC
SKU# PP-256SI
  • Unit Weight: 67 lb
  • Shipping Weight: 103 lb
PowerPro 256Si
The Everlast PowerPro 256Si is a true problem solver, combining powerful AC/DC TIG welding, DC Stick welding, and plasma cutting in a compact, inverter-based design. Built for fabrication, repairs, and maintenance, it’s an excellent choice when space is limited in the shop, on the jobsite, or on a service truck. By bringing welding and cutting together in one versatile unit, it eliminates the need to choose between a welder and a plasma cutter—or the need to stretch your budget to purchase both.
With up to 250 amps of AC/DC TIG output and 200 amps of DC Stick output, the PowerPro 256Si provides the power and versatility to tackle a wide range of welding tasks. A comprehensive set of adjustable controls lets you fine-tune welding performance for precise work and demanding repairs.
The integrated 60-amp plasma cutter makes cutting metals up to 3/4+" easy and convenient. The iPT 60 plasma cutting torch is designed for extended consumable life. Together, these capabilities let you move from cutting to welding with one versatile machine.
Designed for practical, everyday utility, the PowerPro 256Si offers strong value for professionals and serious hobbyists who need portable, all-in-one welding and cutting capability.
  2. 10,500 Surge Watts
  2. E6011 use is permissible but performance may be brand dependent
240V 1 Phase 50/60Hz: 38 A
240V 1 Phase 50/60Hz: 30 A
Cooler Control
Runs Continuously
240V 1 Phase 50/60Hz TIG Amp AC Output Range: 20 to 250 Amps
240V 1 Phase 50/60Hz TIG Volt AC Output Range: 10.8 to 20 Volts
240V 1 Phase 50/60Hz TIG Amp DC Output Range: 5 to 250 Amps
240V 1 Phase 50/60Hz TIG Volt DC Output Range: 10.2 to 20 Volts
82V
TIG Start Type
Lift Start With Remote
HF Start with Point Gap Start
Start Amp Range AC
20-250A
Start Amp Range DC
5-250A
End Amp Range AC
20-250A
End Amp Range DC
5-250A
0-10 Seconds
0-25 Seconds
0-10 Seconds
0-25 Seconds
TIG Pulse
AC
AC Pulse Type
DC TIG Pulse Wave Shape
Square
DC Pulse Frequency
5-250 Hz
AC Pulse Frequency
5-250 Hz
10-90%
Pulse Amperage
5-95% of Welding Amperage
AC Frequency
20-250 Hz
AC Balance
10-90% of Positive Electrode
AC Wave Forms
Square
.007" to 1/2"
.007" to 1/2"
.025"- 5/16"
1/16"- 5/32" (3/16" some types, depending upon manufacturer)
  1. Up to 5/8" daily use
  2. Up to 3/4" clean cut
  3. Up to 1" severance cut
  4. Pierce up to 5/8"
  1. NOT RATED FOR CNC APPLICATIONS. DO NOT USE OR WARRANTY WILL BE VOIDED.
  • Rail Car Industry
  • Pipe and Structural
