PowerPlasma 25i XTR
SKU# PT-25i-XTR
- Unit Weight: 14 lb
- Shipping Weight: 20 lb
- Unit Dimensions: 5.5 in × 13.75 in × 9 in
The PowerPlasma 25XTR is a compact 120V plasma cutter designed for maximum portability and performance. This unit works well in hand cutting environments that cut metals up to 1/4" on a daily basis. The unit works well for a wide spectrum of applications, everything from a portable repair unit to being used to hand cut artistic designs.
- 120V input
- Comfortable and maneuverable iPT 25 hand cutting torch
- Compact size with low weight
- Highly portable
- Cut guide printed on front panel
Generator Requirements*:
- 4,500 Surge Watts
*Not following these requirements will void the plasma cutters's warranty.
| Max Inrush Amps (I1Max) | 120V 1 Phase 50/60Hz: 30 A
| Rated Effective Amps (I1Eff) | 120V 1 Phase 50/60Hz: 18 A
| LCD Screen | No
| User Interface | Analog/No Display
| Memory | No
| Plasma Duty Cycle 120V 1 Phase 50/60Hz | 120V 1 Phase 50/60Hz: 35% Duty Cycle @ 40°C at 25A/90V Rated Output
120V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 20A/88V Rated Output
120V 1 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 15A/86V Rated Output
| Open Circuit Voltage (OCV) | 400V
| Torch Type | iPT25 Hand Torch
| CNC Capable/Ready | No
| Gouging Capable | No
| Gouging Duties | No Gouging Permitted, Voids warranty
| Drag Cutting | Yes, but only with included standoff
| Post Flow Timer | Automatic
| Recommended Flow Rate (Air) | 3.5 CFM
| Maximum Supply Pressure | 90
| Compressor Built In | No
| Recommended Minimum Compressor Size | 20 gallon
| Recommended Cutting Pressure Range | 55-62 PSI
| Remote | 2T
| Tip Saver Function | No
| Location of CNC Port | No CNC Port
| Torch Connector Type | Threaded Screw-On
- Up to 1/4" daily use
- Up to 5/16" clean cut
- Up to 3/8" severance cut
- Pierce up to 5/16"
Units are supplied with a starter set of consumables intended primarily for cutting in the 20-25 amp range.
- NOT RATED FOR CNC APPLICATIONS. DO NOT USE OR WARRANTY WILL BE VOIDED.
- Artistry
- iPT 25 Torch
- 6 ft Work Clamp and cable
- Consumable Starter Kit
