PowerARC 161STH, view 1
PowerARC 161STH, view 2
PowerARC 161STH, view 3
SKU# PA-161STH
PowerARC 161STH
$589.00
$469.00
Save - $120.00
PowerARC 161STH
SKU# PA-161STH
  • Unit Weight: 17 lb
  • Shipping Weight: 23 lb
  • Unit Dimensions: 7 in × 17 in × 11 in
PowerARC 161STH
The compact Dual Voltage PowerARC 161STH is a great choice for portable welding repair. Equally at home welding Stick or using the DC TIG function, the PowerARC 161STH delivers quality welds time after time. The unit can be used with either the torch switch in 2T or 4T mode, or it can be used with the optional foot pedal. The unit features stable, clean HF starts for DC TIG, making starting clean and reliable. Fully featured with all the Stick functions you'd need, the PowerARC 161STH can also weld with E6010/Cellulosic rods and deliver, X-ray quality welds with E7018, E309, or any iron powder or titania fluxed rods. Hot Start and Arc force controls allow consistent control of arc striking and arc quality. For safety, the unit also features VRD and Stuck Rod (Anti-Stick) functions.
  1. HF Start, Lift Start DC TIG output
  2. Simple, easy to use DC Pulse for TIG
  3. Dual 120 and 240V operation
  4. E6010/Cellulosic Rod capability
  5. VRD safety
  6. Anti-Stick to prevent rod flame out when stuck in the puddle
  7. Adjustable Arc force and Hot Start
8000 Watts Surge Rating
TIG Operation:
The unit features DC TIG operation and supports the ability to use an optional foot pedal.
120V 1 Phase 50/60Hz
120V 1 Phase 50/60Hz: 27.1 A
240V 1 Phase 50/60Hz: 29.2 A
120V 1 Phase 50/60Hz: 17 A
240V 1 Phase 50/60Hz: 18 A
Stick Duty Cycle 120V 1 Phase 50/60Hz
120V 1 Phase 50/60Hz: 35% Duty Cycle @ 40°C at 90A/23.6V Rated Output
120V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 70A/22.8V Rated Output
120V 1 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 55A/22.2V Rated Output
Stick Duty Cycle 240V 1 Phase 50/60Hz
240V 1 Phase 50/60Hz: 35% Duty Cycle @ 40°C at 160A/26.4V Rated Output
240V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 130A/25.2V Rated Output
240V 1 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 100A/24V Rated Output
Stick Output Range 120V 1 Phase 50/60Hz
120V 1 Phase 50/60Hz Stick Amp DC Output Range: 10 to 90 Amps
120V 1 Phase 50/60Hz Stick Volt DC Output Range: 20.2 to 23.6 Volts
Stick Output Range 240V 1 Phase 50/60Hz
240V 1 Phase 50/60Hz Stick Amp DC Output Range: 10 to 160 Amps
240V 1 Phase 50/60Hz Stick Volt DC Output Range: 20.2 to 26.4 Volts
70 (VRD <18)V
Hot Start
Adjustable
Hot Start Time
Adjustable
Arc Force
Adjustable
Voltage Reduction (VRD)
Anti-Stick Protection
Stick Pulse
Functions with Remote
PowerSet Simplified Pro Setup
Carbon Arc Capable
1/8"
TIG Function
Built In Gas Valve Standard Torch
.015" to 1/4"
.015" to 1/4"
1/16"- 5/32"
  • Pipe and Structural
