PowerARC 140STi, view 1
PowerARC 140STi, view 2
SKU# PA-140STI
PowerARC 140STi
$379.00
$359.00
Save - $20.00
PowerARC 140STi
SKU# PA-140STI
  • Unit Weight: 10 lb
  • Shipping Weight: 25 lb
  • Unit Dimensions: 5 in × 12 in × 9 in
PowerARC 140STi
The PowerARC 140STi is a compact, dual voltage welder built for everyday jobs with stick electrodes up to 1/8 inch. It’s a practical choice for do it yourself projects and for professionals who need a portable machine for light repairs. It runs E7018, E7014, and E6013 steel electrodes, as well as E309L electrodes for stainless steel applications. For added flexibility, it also offers basic DC lift start TIG capability with the included 17V TIG torch.
  1. Dual Voltage 120/240V input for maximum portability
  2. VRD (Voltage Reduction Device) Lowers OCV in stick mode for safety
  3. Arc force improves performance as arc length changes
  4. Hot start improves arc starting capability
  5. Smooth, stable arc on iron powder and titania fluxed rods
  6. DC TIG function with live lift start (no remote control capability)
6000 Watts Surge Rating
TIG Operation:
The unit features DC TIG operation. However it is lift start only and does not support remote/foot pedal control operation.
The torch is a gas valve torch. An optional regulator will need to be connected to the torch direct. Additional fittings may be required.
Stick Operation:
This unit has both VRD and Anti-Stick functions. Use of these features may increase stick arc starting difficulty, especially if both are used together. VRD should be used when safety protocols dictate. Use a double tap or an extended drag to start the Stick arc.
120V 1 Phase 50/60Hz
120V 1 Phase 50/60Hz: 28.1 A
240V 1 Phase 50/60Hz: 24.2 A
120V 1 Phase 50/60Hz: 18.3 A
240V 1 Phase 50/60Hz: 15.7 A
Stick Duty Cycle 120V 1 Phase 50/60Hz
120V 1 Phase 50/60Hz: 35% Duty Cycle @ 40°C at 80A/23.2V Rated Output
120V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 65A/22.6V Rated Output
120V 1 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 50A/22V Rated Output
Stick Duty Cycle 240V 1 Phase 50/60Hz
240V 1 Phase 50/60Hz: 35% Duty Cycle @ 40°C at 140A/25.6V Rated Output
240V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 110A/24.4V Rated Output
240V 1 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 85A/23.4V Rated Output
Stick Output Range 120V 1 Phase 50/60Hz
120V 1 Phase 50/60Hz Stick Amp DC Output Range: 10 to 80 Amps
120V 1 Phase 50/60Hz Stick Volt DC Output Range: 20.4 to 24.2 Volts
Stick Output Range 240V 1 Phase 50/60Hz
240V 1 Phase 50/60Hz Stick Amp DC Output Range: 10 to 140 Amps
240V 1 Phase 50/60Hz Stick Volt DC Output Range: 20.4 to 25.6 Volts
70V
Hot Start
Adjustable
Hot Start Time
Adjustable
Arc Force
Adjustable
Voltage Reduction (VRD)
Anti-Stick Protection
Stick Pulse
Functions with Remote
PowerSet Simplified Pro Setup
Carbon Arc Capable
1/8"
Use 6011 for best results
TIG Function
TIG Rig with Gas Valve Torch
Recommended Range of Welding Rod Diameters*:
1/16"- 1/8"
*Range of welding rod diameters is based on welding rod type and manufacturer's actual recommendations. Always consult manufacturer's recommendations for Amp range and minimum/maximum welding capability of each rod type.
.025" to 3/16"
.015" to 3/16"
  • Rail Car Industry
  • Pipe and Structural
