Power i-TIG 201, view 1
Power i-TIG 201, view 2
Power i-TIG 201, view 3
Power i-TIG 201, view 4
Power i-TIG 201, view 5
SKU# PIT-201
Power i-TIG 201
Analog DC
$729.00
$515.00
Save - $214.00
Power i-TIG 201
Analog DC
SKU# PIT-201
  • Unit Weight: 30 lb
  • Shipping Weight: 38 lb
  • Unit Dimensions: 7.5 in × 17.5 in × 11.11 in
Power i-TIG 201
The Power i-TIG 201 is a compact dual voltage DC TIG and DC Stick welder designed for precise welding on many different types of metal. The compact size and dual voltage design allows the user to setup almost anywhere. With excellent low amperage starts, the unit excels on welding thin metals. The Power i-TIG 201 is comfortable in any professional setting with Pulse TIG capability and stable arc that is stable enough for a gunsmith to use and powerful enough for running a TIG root in sanitary pipe. The Stick function also is smooth and stable on titania and iron powder rods.
  2. 8500 Surge Watts
  2. E6011 use is permissible
120V 1 Phase 50/60Hz
120V 1 Phase 50/60Hz: 28.6 A
240V 1 Phase 50/60Hz: 27.5 A
120V 1 Phase 50/60Hz: 18 A
240V 1 Phase 50/60Hz: 17 A
Cooler Control
Runs Continuously
120V 1 Phase 50/60Hz: 35% Duty Cycle @ 40°C at 125A/15V Rated Output
120V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 100A/14V Rated Output
120V 1 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 80A/13.2V Rated Output
240V 1 Phase 50/60Hz: 35% Duty Cycle @ 40°C at 200A/18V Rated Output
240V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 160A/16.4V Rated Output
240V 1 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 130A/15.2V Rated Output
120V 1 Phase 50/60Hz TIG Volt DC Output Range: 10.2 to 15 Volts
240V 1 Phase 50/60Hz TIG Amp DC Output Range: 5 to 200 Amps
70V
TIG Start Type
Lift Start With Remote
HF Start with Point Gap Start
Start Amp Range DC
Fixed
End Amp Range DC
Fixed
0-5 Seconds
0-25 Seconds
0-5 Seconds
0-5 Seconds
TIG Pulse
DC TIG Pulse Wave Shape
Square
DC Pulse Frequency
0-250 Hz
10-90%
Pulse Amperage
5-95% of Welding Amperage
.007" to 5/16"
.007" to 5/16"
1/16"- 5/32"
  • Pipe and Structural
  • Gunsmithing
