Lightning MTS 212
SKU# LMTS-212
- Unit Weight: 60 lb
- Unit Dimensions: 9.25 in × 26 in × 15 in
The Lightning MTS 212 combines 210A AC/DC TIG, 180A Stick, and spool-gun MIG capability in a compact, portable design. Dual-voltage operation lets you work on 120V or 240V, with reduced output on 120V—ideal for small shops, home garages, and portable repair work.
The large TFT LCD color display keeps all settings for each process on one page for quick, straightforward setup. Name, save, and lock up to 30 custom programs for repeat jobs.
TIG features include AC/DC pulse up to 150 Hz, adjustable AC balance and frequency, pre- and post-flow, start and end amperage, and up/down slope controls. Stick mode provides E6010 capability, adjustable Hot Start and Arc Force, and a smooth, stable arc for electrodes up to 5/32".
For MIG welding, the Lightning uses a compatible Parker DSP 240A spool gun in place of an internal wire feeder. It supports steel, stainless steel, aluminum, and gas-shielded flux-core wire up to .045" with the appropriate drive rolls. The spool gun’s extended reach adds flexibility for shop fabrication and on-site repairs.
- Dual Voltage 120/240V input for go anywhere capability
- AC/DC TIG, DC Stick with spool gun for MIG
- Intuitive navigation and setup
- Synergic PowerSet mode for easier setup if desired
- Save up to 30 favorite programs
- Spool Gun included with speed control on gun itself
- 7500 Surge Watts
- This unit MIG welds with a Parker DSP 240A or optional Parker DSP 360A spool gun only. Be sure to purchase additional drive rolls for feeding theIt does not have an internal mounted wire feeder and does not work with externally mounted wire feeders.
240V 1 Phase 50/60Hz: 28 A
| Rated Effective Amps (I1Eff) | 120V 1 Phase 50/60Hz: 23 A
240V 1 Phase 50/60Hz: 23 A
| LCD Screen | 4.3 inches
| Type | TFT
| Resolution | 720
| Memory | 30 Programs
| TIG Duty Cycle 120V 1 Phase 50/60Hz | 120V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 125A/14.8V Rated Output
120V 1 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 100A/V Rated Output
| TIG Duty Cycle 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 210A/18.4V Rated Output
| TIG Output Range 120V 1 Phase 50/60Hz | 120V 1 Phase 50/60Hz TIG Amp AC Output Range: 15 to 125 Amps
120V 1 Phase 50/60Hz TIG Volt AC Output Range: 10.6 to 15 Volts
120V 1 Phase 50/60Hz TIG Volt DC Output Range: 10.2 to 15 Volts
| TIG Output Range 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz TIG Amp AC Output Range: 15 to 210 Amps
240V 1 Phase 50/60Hz TIG Volt AC Output Range: 10.6 to 18.4 Volts
240V 1 Phase 50/60Hz TIG Amp DC Output Range: 5 to 210 Amps
240V 1 Phase 50/60Hz TIG Volt DC Output Range: 10.2 to 18.4 Volts
| Open Circuit Voltage (OCV) | 84V
| TIG Start Type | HV/HF Solid State (Touchless) Start
| Start Amp Range AC | 15-210A
| Start Amp Range DC | 5-210A
| End Amp Range AC | 15-210A
| End Amp Range DC | 5-210A
| TIG Pulse | AC
| AC Pulse Type | Standard
| DC Pulse Frequency | 150 Hz
| AC Pulse Frequency | 150 Hz
| Pulse Amperage | 10-90% of Welding Amperage
| AC Frequency | 20-250 Hz
| AC Balance | 10-70% of Positive Electrode
| AC Wave Forms | Square
| MIG Duty Cycle 120V 1 Phase 50/60Hz | 120V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 125A/20.3V Rated Output
120V 1 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 100A/19V Rated Output
| MIG Duty Cycle 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 210A/24.5V Rated Output
240V 1 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 160A/22V Rated Output
| MIG Output Range 120V 1 Phase 50/60Hz | 120V 1 Phase 50/60Hz MIG Amp DC Output Range: 30 to 125 Amps
| MIG Output Range 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz MIG Amp DC Output Range: 30 to 210 Amps
240V 1 Phase 50/60Hz MIG Volt DC Output Range: 15.5 to 24.5 Volts
| Post-Flow Time | 0-20 Seconds
| Up-Slope Time | 0-1 Seconds
| MIG Pulse | None
| Spool Sizes | 4”
| Stock Drive Roll Wire Sizes Installed | .040”
| Number of Wire Drive Rolls (Top and Bottom) | 2
U-Groove (Aluminum)
| Water Cooler Capable | Yes
| Spool Gun Capable | Yes
| Push Pull Gun Capable | No
| MIG Functions | Burn Back
Run-In
| Wire Feed Speed | 120V: 400IPM 240V: 600IPM
| Torch/Gun | Parker DSP 240 Spool Gun 25 ft.
| Important MIG Specification Notes | Only Spool Gun operation is supported for MIG processes
| Stick Duty Cycle 120V 1 Phase 50/60Hz | 120V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 100A/24V Rated Output
| Stick Duty Cycle 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 170A/26.8V Rated Output
240V 1 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 130A/26.4V Rated Output
| Stick Output Range 120V 1 Phase 50/60Hz | 120V 1 Phase 50/60Hz Stick Amp DC Output Range: 10 to 100 Amps
120V 1 Phase 50/60Hz Stick Volt DC Output Range: 20.4 to 24 Volts
| Stick Output Range 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz Stick Amp DC Output Range: 10 to 170 Amps
240V 1 Phase 50/60Hz Stick Volt DC Output Range: 20.4 to 26,8 Volts
| Arc Force | Adjustable
| Anti-Stick Protection | No
| Adjustable AC Frequency | No
| Functions with Remote | No
Common Recommended Metal Types and capabilities For MIG with Spool Gun Operation*:
24 gauge to 5/16"
20 gauge to 5/16"
1/8"- 5/16""
.015" to 5/16"
.015" to 5/16"
.025"- 1/4"
1/16"- 5/32"
- Pipe and Structural
- Gunsmithing
- NOVA 26 Series Air-Cooled Rigid Neck TIG Torch 12.5 Ft. 25 DINSE-Type Connector (No Gas Thru)
- Parker DSP 240A Spool Gun (7 Pin) 25 Ft. Euro Quick Connect
- 240V to 120V Pigtail adapter
- TIG Starter Consumable Kit (Does not include Tungsten)
- 6.5 Ft. Power Cable and NEMA 6-50 Power Plug
