Lightning 275 MTS, view 1
Lightning 275 MTS, view 2
Lightning 275 MTS, view 3
Lightning 275 MTS, view 4
SKU# LMTS-275
Lightning 275 MTS
MIG
$3,099.00
$2,350.00
Save - $749.00
Lightning 275 MTS
MIG
SKU# LMTS-275
  • Unit Weight: 95 lb
  • Unit Dimensions: 11.5 in × 26 in × 25 in
Lightning 275 MTS
Built for professional welders, the Lightning MTS 275 brings the power and versatility to handle demanding fabrication, maintenance, and repair work in one compact machine. From the shop to the field, its 275A MIG output, TIG capability, and 220A Stick output—including E6010—give you more ways to get the job done. It handles short-circuit and spray arc MIG welding, with dedicated settings for aluminum, stainless steel, and gas-shielded or gasless flux-core welding. Push-pull gun capability expands its versatility even further.
Setup is quick and straightforward. The improved PowerSET function provides starting settings based on basic application information in MIG, TIG, and Stick modes. All settings for the selected process appear on a single screen, keeping adjustments within easy reach. An updated HV TIG start system delivers more efficient starts.
Built for demanding work, the Lightning MTS 275 delivers a 60% duty cycle at maximum rated output in all three processes, with 100% duty cycle at 200A in MIG and TIG or 175A in Stick. When the job takes you away from the shop, 120V capability keeps you working with reduced output and a generous duty cycle.
  1. Dual Voltage Operation allows maximum go-anywhere performance
  2. MIG,TIG and Stick operation handles almost any common welding chore
  3. Cart and Cooler for TIG available as an option and works with rear outlet
  4. Spool Gun Capable (spool gun optional)
  5. Run-in features improves arc starting in MIG mode
  6. Push Pull Gun Capable (Push-Pull gun optional)
  7. 5.1" LCD HD 720 Screen for easy view of parameters
  8. 4 Roller drive system for smooth feeding of wire on longer guns and push-pull guns
  9. 12" or 8" roll capacity (10-12 lb. or 30-44lb.) provide economical choices of wire selection.
  2. Surge Watts 13,500
120V 1 Phase 50/60Hz
120V 1 Phase 50/60Hz: 43 A
240V 1 Phase 50/60Hz: 53 A
120V 1 Phase 50/60Hz: 34 A
240V 1 Phase 50/60Hz: 41 A
5.1 inches
Type
TFT
Resolution
720
30 Programs
Cooler Control
Runs Continuously
120V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 150A/21.5V Rated Output
120V 1 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 120A/20V Rated Output
120V 1 Phase 50/60Hz MIG Amp DC Output Range: 30 to 150 Amps
80V
Start Wire Feed Speed
Adjustable
End Wire Feed Speed
Adjustable
0-10 Seconds
0-30 Seconds
0-1 Seconds
0-1 Seconds
MIG Pulse
None
Spool Sizes
8”
12”
.035”
V-Groove
4
V-Groove
PowerSet Simplified Pro Setup
Water Cooler Capable
Spool Gun Capable
MIG Functions
Wire Jog
Run-In
Spot
Stitch
Wire Feed Speed
120V: 425IPM 240V: 600 IPM
Torch/Gun
North 36 Series 10 Ft.
This unit is equipped with a heavy duty 36 series MIG gun designed for Spray arc welding and using larger .045" and .062" wires. If welding below 230A, purchase a 24 Series gun. If using .035" or smaller wire, also purchase a blue .023"-.035" liner for the 24 series gun or the 36 series gun
24 gauge to 3/8"
20 gauge to 3/8"
1/8"- 7/16""
.015" to 5/16"
.015" to 5/16"
.025"- 5/16"
1/16"- 7/32"
  • Rail Car Industry
  • Pipe and Structural
Downloads
