Results 1 to 8 of 8
Thread: need help on a mig welder
    Default need help on a mig welder
    Was doing a lot of repair work and have moved into production work and thus I am in need of a mig welder for the speed mig welding can give me over tig and my 250EX. It's there a unit that has mig and a plasma cutter? I know I remember vaguely that some offer tig/plasma combos. Also will be unloading my 250EX with a 250cf bottle lenses/consumables brand new 20 torch, 26 factory torch and a 17 torch that needs to be repaired (it was part of a bunch of stuff I bought and was a bonus). Interested msg me. Ps only 2 bottles of argon through the unit, works flawless. Local pickup socal.
    Anyway I can't seem to access the mig page any father than the page that shows the 3 categories of mig welders. Right now I'm kinda set on the miller 210 autoset found a place I can get it shipped for 799.00 . I know my 250EX has been a champ but with a gimpy left arm and not being able to use a foot pedal I need to switch to mig. Any ideas would be appreciated. Also any links to where I can see some specs and prices on the new Everlast units
    Oleg, you gone for the holidays?
    Anyway. Merry Christmas and happy New year all
    Don
    Don
    MTS 200 workhorse
    PowerTig 250EX <---sweet
    80 amp HF inverter arc welder
    Lincoln Buzzbox
    Rotobrute AC-35 Mag Drill
    Milwaukee mag drill
    Fullerton, Ca
    USA
    Thanks Rambo, taking a look now.
    Cheers
    Don
    Sent from my Nexus 7 using Tapatalk 2
    Don
    MTS 200 workhorse
    Lincoln Buzzbox
    Milwaukee mag drill
    Fullerton, Ca
    USA
    honestly I have been using my Everlast MTS200s and I think its a good machine. I came from using a lincoln weldpak and the only thing I have found about the MTS200s is it seems to have a problem with getting a good ground. I do think that upgrading the clamp would do it wonders though. At first I had problems with the wire melting back and getting stuck in the torch but after adjusting it basically all the way down, I have not had any issues with it. Overall, I think the machine welds as good as the lincoln.
    Is there not enough range in the burn back timer control?
    There is actually quite a bit of range. When the unit arrived it was turned up and for me I had to turn it most the way down. I assume this could be different depending on the person using it.
    Ended up turning mine down also, probably the 9o clock position maybe .04 sec. Other than that and missing consumables it's a great machine
    Don
    MTS 200 workhorse
    Lincoln Buzzbox
    Milwaukee mag drill
    Fullerton, Ca
    USA
    How much power are you needing? What thickness are you planning to weld? If your doing a lot of 1/2" go with a Imig250p or MTS250. Try your best to get what you need, & not make a purchase on what will get you by. A mig welder purchase is something you want to think about your possible long term needs.
  1. Mystery Welder Revealed: 2012 DIGITAL POWERTIG 210EXT TIG/STICK welder
