Cyclone 312i Pro with Undercarriage
SKU# CLN-312I-PRO
- Shipping Weight: 163 lb
- Unit Dimensions: 11.25 in × 33.5 in × 25 in
The Everlast Cyclone 312i-Pro is a professional, heavy-duty MIG/Stick welder ready for almost any work environment. It delivers up to 315A of MIG power and 250A of Stick power, with a 35% duty cycle at maximum output. Its integrated undercarriage makes it easy to roll around shops or jobsites with hard surfaces. The cart system includes a protective roll bar surrounding the cabinet and a rear gas cylinder carrier to keep your welding setup together.
A bright 4.3" color display keeps settings easy to read. PowerSet simplifies setup with recommended voltage and wire speed settings based on your gas, wire type, and wire size, with fine-tuning available for specific applications. Adjustable gas flow, inductance, and burnback help refine MIG performance, while 2T/4T controls and spot and stitch timers support long seams and consistent welds. Stick mode handles electrodes including E6010 and offers PowerSet settings for a variety of steel rods. Memory storage saves your preferred settings for both processes.
- The Cyclone 312i Pro model includes cart system which includes roll over bars with rear cylinder carrier
- 240V input
- 4.3" HD TFT screen
- Can use spool gun or stock gun with polymer liner for Aluminum with U groove drive rolls
- Additional polymer liner, U-groove drive roll and Spool Gun are optional
- 16,500 Surge Watts
| Max Inrush Amps (I1Max) | 240V 1 Phase 50/60Hz: 64 A
| LCD Screen | 5.1 inches
| Type | TFT
| Resolution | HD 720
| Memory | 30 Programs
| MIG Duty Cycle 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz: 40% Duty Cycle @ 40°C at 315A/29.8V Rated Output
240V 1 Phase 50/60Hz MIG Volt DC Output Range: 15.5 to 24 Volts
| Up-Slope Time | 0-1 Seconds
2T SP
4T SP
| MIG Pulse | None
| Spool Sizes | 8”
12”
Steel V-groove
| Water Cooler Capable | Yes
| Spool Gun Capable | Yes
| Push Pull Gun Capable | Yes
| MIG Functions | Wire Jog
Run-In
| Other MIG Functions | Spot,
Stitch,
Undercarriage
| Wire Feed Speed | 600IPM
| Torch/Gun | 36 Series 10 Ft. (North)
| Important MIG Specification Notes | Purchase a separate liner for each wire size that will be used. For under 230A operation, purchase a 24 series gun.
This model includes a cart system (undercarriage) with a cylinder rack in the rear.
| Stick Duty Cycle 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz: 40% Duty Cycle @ 40°C at 250A/30V Rated Output
| Arc Force | Adjustable
| Anti-Stick Protection | Yes
| Functions with Remote | No
| TIG Duty Cycle 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz: 40% Duty Cycle @ 40°C at 315A/22.6V Rated Output
| TIG Output Range 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz TIG Amp DC Output Range: 10 to 315 Amps
240V 1 Phase 50/60Hz TIG Volt DC Output Range: 10.4 to 22.6 Volts
24 gauge to 1/2"
22 gauge to 1/2"
1/8-3/8"
1/16"- 3/16"
.015" to 1/2"
.015" to 1/2"
- Aerospace
- Parker DSP 360A Spool Gun 25 Ft. Euro Quick Connect
