Cyclone 212i with North SM200N Spool Gun Package
SKU# CLN-212I-SM200N-MTS-BUNDLE-12N
- Unit Dimensions: 9 in × 18 in × 13 in
This Cyclone 212i spool gun bundle package includes Everlast Cyclone 212i and the North SM200N-MTS spool gun. Everything included in the standard Cyclone 212i accessory package is also included in this package. This spool gun package allows use of the 4" spools for long distance wire feeding. The spool gun includes .035" aluminum U-groove drive roll. Order additional drive rolls for different sized aluminum and steel wires for the spool gun.
Includes:
- Cyclone 212i MIG/DC Stick/ DC Live Lift TIG welder
- Cyclone 212i accessory package
- North SM200N Spool Gun with 25 Ft Cable
- 10,500 Surge Watts
- This welder performs best with .030" and .035" and solid wire sizes. .045/.047" sizes work best with aluminum and gasless flux-cored wires. With .023 and .030" diameter steel or stainless wires, do not use with guns longer than 10 Ft.
- This welder is not recommended for Gas-Shielded Flux-Cored operation. Choose a larger machine such as the Cyclone 262i for this type of operation.
| Max Inrush Amps (I1Max) | 120V 1 Phase 50/60Hz: 33 A
240V 1 Phase 50/60Hz: 40 A
| Rated Effective Amps (I1Eff) | 120V 1 Phase 50/60Hz: 20 A
240V 1 Phase 50/60Hz: 20 A
| LCD Screen | 4.3 inches
| Type | TFT
| Resolution | HD 720
| Memory | 30 Programs
| MIG Duty Cycle 120V 1 Phase 50/60Hz | 120V 1 Phase 50/60Hz: 35% Duty Cycle @ 40°C at 125A/20.3V Rated Output
| MIG Duty Cycle 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz: 15% Duty Cycle @ 40°C at 230A/25.5V Rated Output
| MIG Output Range 120V 1 Phase 50/60Hz | 120V 1 Phase 50/60Hz MIG Amp DC Output Range: 30 to 125 Amps
| MIG Output Range 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz MIG Amp DC Output Range: 30 to 260 Amps
240V 1 Phase 50/60Hz MIG Volt DC Output Range: 15.5 to 26.5 Volts
| Pre-Flow Time | 0-5 Seconds
| Post-Flow Time | 0-15 Seconds
| MIG Pulse | None
| Spool Sizes | 4”
8”
| Stock Drive Roll Wire Sizes Installed | .030”
.035”
| Number of Wire Drive Rolls (Top and Bottom) | 2
| Water Cooler Capable | No
| Spool Gun Capable | Yes
| Push Pull Gun Capable | No
| MIG Functions | Wire Jog
| Other MIG Functions | Spot
Stitch
| Wire Feed Speed | 120V: 400IPM 240V: 600IPM
| Torch/Gun | 24 Series 10 Ft. (North)
| Stick Duty Cycle 120V 1 Phase 50/60Hz | 120V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 80A/23.2V Rated Output
| Stick Duty Cycle 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz: 35% Duty Cycle @ 40°C at 175A/27V Rated Output
240V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 130A/25.2V Rated Output
240V 1 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 100A/24V Rated Output
| Stick Output Range 120V 1 Phase 50/60Hz | 120V 1 Phase 50/60Hz Stick Amp DC Output Range: 10 to 100 Amps
120V 1 Phase 50/60Hz Stick Volt DC Output Range: 24 to 22.4 Volts
| Stick Output Range 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz Stick Amp DC Output Range: 10 to 175 Amps
240V 1 Phase 50/60Hz Stick Volt DC Output Range: 20.4 to 27 Volts
| Arc Force | Adjustable
| Anti-Stick Protection | Yes
| Functions with Remote | No
| TIG Duty Cycle 120V 1 Phase 50/60Hz | 120V 1 Phase 50/60Hz: 35% Duty Cycle @ 40°C at 120A/15V Rated Output
120V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 100A/14V Rated Output
120V 1 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 80A/13.2V Rated Output
| TIG Duty Cycle 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz: 35% Duty Cycle @ 40°C at 230A/19.2V Rated Output
240V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 180A/17.2V Rated Output
240V 1 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 140A/15.6V Rated Output
| TIG Output Range 120V 1 Phase 50/60Hz | 120V 1 Phase 50/60Hz TIG Amp DC Output Range: 10 to 125 Amps
120V 1 Phase 50/60Hz TIG Volt DC Output Range: 15 to 13.2 Volts
| TIG Output Range 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz TIG Amp DC Output Range: 10 to 230 Amps
240V 1 Phase 50/60Hz TIG Volt DC Output Range: 15 to 19.2 Volts
24 gauge to 5/16"
22 gauge to 5/16"
1/8-1/4"
1/16"- 5/32"
.015" to 1/4"
.015" to 1/4"
- 24 Series MIG Gun 3m 10 ft.
- North SM200-MTS Spool Gun 20 Ft. Euro Quick Connector
- 240V to 120V Pigtail adapter
