Cyclone 200es and SM3035 Spool Gun Bundle Package
SKU# CLN-200ES-SM3035N-BUNDLE-11
The 200es MIG package includes everything in the 200es MIG welder package plus the SM3035N spool gun. This setup allows you to use smaller spools of wire at a further distance than a typical MIG gun will allow.
Includes:
- Cyclone 200es MIG welder
- Cyclone 200es MIG welder accessory package
- SM3035N Spool Gun 20 Ft. with Euro Connector
- 7500 Surge Watts
- This unit does allow use with a spool gun. However, due to lower wire speeds this unit has, the welding range for aluminum will be limited unless .047" wire is used. This unit performs best with a polymer liner in the Stock gun, using U-groove drive rolls to feed from the main cabinet into the stock gun.
- This unit is not meant for Gas-Shielded Flux-Cored use. Do not use with this product.
- Do not use .023 and .030" wire with the optional 15 ft. MIG gun. Gun feeding issues will result.
- Do not use larger than .035" solid steel or stainless wire with this unit. With .035" or larger wire the machine may throttle back output to prevent damage to the machine as the wire feed speed selected may cause over Amperage. In this case, the welder may seem to sputter or feed irregularly.
| Max Inrush Amps (I1Max) | 120V 1 Phase 50/60Hz: 30.2 A
240V 1 Phase 50/60Hz: 28.2 A
| Rated Effective Amps (I1Eff) | 120V 1 Phase 50/60Hz: 17 A
240V 1 Phase 50/60Hz: 15 A
| LCD Screen | 3.5 inches
| Type | Segmented LCD
| Resolution | 480
| Memory | No
| MIG Duty Cycle 120V 1 Phase 50/60Hz | 120V 1 Phase 50/60Hz: 25% Duty Cycle @ 40°C at 115A/19.75V Rated Output
120V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 75A/17.75V Rated Output
120V 1 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 60A/17V Rated Output
| MIG Duty Cycle 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz: 25% Duty Cycle @ 40°C at 180A/23V Rated Output
240V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 120A/20V Rated Output
240V 1 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 90A/18.5V Rated Output
| MIG Output Range 120V 1 Phase 50/60Hz | 120V 1 Phase 50/60Hz MIG Amp AC Output Range: 30 to 200 Amps
120V 1 Phase 50/60Hz MIG Volt AC Output Range: 15.5 to 24 Volts
| Open Circuit Voltage (OCV) | 72V
| Pre-Flow Time | Fixed
| Post-Flow Time | Fixed
| MIG Pulse | None
| Stock Drive Roll Wire Sizes Installed | .023”
.030”
| Number of Wire Drive Rolls (Top and Bottom) | 2
| Water Cooler Capable | No
| Spool Gun Capable | Yes
| Push Pull Gun Capable | No
| Wire Feed Speed | 120: 360 IPM 240V: 480 IPM
| Torch/Gun | 15 Series 15 Ft.
| Stick Duty Cycle 120V 1 Phase 50/60Hz | 120V 1 Phase 50/60Hz: 25% Duty Cycle @ 40°C at 100A/24V Rated Output
120V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 65A/22.6V Rated Output
120V 1 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 50A/22.0V Rated Output
| Stick Duty Cycle 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz: 25% Duty Cycle @ 40°C at 160A/26.4V Rated Output
240V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 105A/24.2V Rated Output
240V 1 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 80A/23.2V Rated Output
| Stick Output Range 120V 1 Phase 50/60Hz | 120V 1 Phase 50/60Hz Stick Amp DC Output Range: 20 to 100 Amps
120V 1 Phase 50/60Hz Stick Volt DC Output Range: 20.8 to 22.0 Volts
| Stick Output Range 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz Stick Amp DC Output Range: 20 to 160 Amps
240V 1 Phase 50/60Hz Stick Volt DC Output Range: 20.8 to 26.4 Volts
| Hot Start | Fixed
| Arc Force | Fixed
| Anti-Stick Protection | No
| Functions with Remote | No
24 gauge to 1/4"
22 gauge to 1/4"
1/8" -3/16" (use .047" wire, with teflon liner in stock gun with U-groove drive rolls. Although the unit does support the use of a spool gun, the spool gun should use larger wire for best results.
- 15 Series MIG Gun 3 m 10 ft.
- SM 3035N Spool Gun (2 Pin Version) 20 Ft. Euro Quick Connector
- Drive Roll V-Groove Single (Steel/Stainless) – .023"-.030" (0.6-0.8mm)
- Spare Contact Tip for MIG guns
- 6.5 Ft. Power cable and NEMA 6-50 Power Plug
- 240V to 120V Pigtail power adapter
