Vortex 405 Pulse MIG Wire Feeder Single Spool, view 1
Vortex 405 Pulse MIG Wire Feeder Single Spool, view 2
SKU# V-405-PS
Single Spool MIG Wire Feeders
$1,099.00
$729.00
Save - $370.00
SKU# V-405-PS
  • Unit Weight: 45 lb
  • Shipping Weight: 50 lb
  • Unit Dimensions: 11 in × 28 in × 16 in
The Vortex 405 pulse wire feeder is a wire feeder that is designed to specifically pair with Everlast CV Power Sources such as the Cyclone 353dpi and Cyclone 573DPi This wire feeder features a large 5.1" HD LCD display, which displays the settings direct on the feeder itself. All MIG and wire feed functions can be selected direct on the feeder, rather than referring to the master CV power source itself for ancillary settings. The feeder also can be used to save programs used in the MIG modes. The feeder also supports water cooled operation of MIG torches. Your choice of Push-pull or spool gun, air or water-cooled, can be connects direct to the Euro-Quick Connector as well.
Maximum Wire Feed Speed
700 IPM
Amperage Rating
500 Amps
Duty Cycle @ Amperage Rating
100%
Maximum Spool Weight
44 lbs
Spool Diameter(s)
12"
Number of Spools
One
Display
Full Digital Display
Number of Drive Rolls
Four
Stock Feeder Drive Roll Sizes
.040-/ 1.0mm.045 .045" (.047 or 3/64")/1.2mm
.062" (1/16") /1.6mm
Supports Gun Types
Spool Gun
Air-Cooled Push Pull-Gun
Water-Cooled Push-Pull Gun
Air-Cooled Standard MIG Gun
Water Cooled Standard MIG Gun
Maximum Recommended Operation Distance from Power Source
75 Ft./Meters
Compatible With
Everlast
Main Case Material Type
Steel
Type of Operation (s)
Synergic
Manual
