TIG Button™ Amp Control Fits Thermal Arc/ SanRex 8 Pin Connector 25 Ft.
SKU# EV-TBS-S-TA-8-8L
- Unit Weight: 1 lb
- Shipping Weight: 2 lb
This button fits the following Thermal Arc® models with the 8 pin connector:
185, 185 TSW, 200 AC/DC, 201GTS
This button fits the following SanRex/Sanaarg® models with the 8 pin connector:
185P, 200 AC/DC
| Connector PIN Count | 8
| Cord Length | 25 Ft.
