TIG Button™ Amp Control Fits Miller® Maxstar (150STH/STL) with 6 Pin Connector 25 Ft.
SKU# EV-TBS-S-ME-6
- Unit Weight: 1 lb
- Shipping Weight: 2 lb
This button fits the following Miller® models with a 6 pin connector:
Maxstar 150STL
Maxstar 150STH
| Connector PIN Count | 6
| Cord Length | 25 Ft.
