TIG Button™  Amp Control Fits Miller® Diversion with RJ45 8 Pin Connector 25 Ft., view 1
SKU# EV-TBS-S-ME-8
$285.00
SKU# EV-TBS-S-ME-8
  • Unit Weight: 1 lb
  • Shipping Weight: 2 lb
This button fits the following Miller® models with a RJ45 8 pin connector:
Diversion
Connector PIN Count
6
Cord Length
25 Ft.
