TIG Button™ Amp Control Fits Lincoln® R Series 6 Pin Connectors 25 Ft.
SKU# EV-TBS-R-LE-6
- Unit Weight: 1 lb
- Shipping Weight: 2 lb
This button fits the following Lincoln® models with a 6 pin connector:
Squarewave:
Tig 200 Tig 275, Tig 300, Tig 355
Invertec:
V160s, V160t, V200t, V250t, V275s, V300 pro, V350 pro
| Connector PIN Count | 6
| Cord Length | 25 Ft.
