TIG Button™  Amp Control Fits Everlast® TIG welders with 7 Pin Female Connector 25 Ft., view 1
SKU# EV-TBS-S-EVF-7
$285.00
SKU# EV-TBS-S-EVF-7
  • Unit Weight: 1 lb
  • Shipping Weight: 2 lb
This button fits the following Everlast® models with a 7 pin female connector
PowerTIG
Power i-TIG
PowerArc (with pedal control capability and connector)
Typhoon
Connector PIN Count
7
Cord Length
25 Ft.
