S-75 Trafimet® Hand Torch Blow Back Start 15 Ft. Threaded Connector, view 1
S-75 Trafimet® Hand Torch Blow Back Start 15 Ft. Threaded Connector, view 2
SKU# TR-S75-15T
Blow-Back/Non HF
$299.00
Blow-Back/Non HF
SKU# TR-S75-15T
  • Unit Weight: 7 lb
  • Shipping Weight: 7 lb
The S-75 Trafimet® is a non-contact, blow back start style 80A rated torch with pilot arc designed for hand cutting. Natively fits PowerPro 256S series multi-process units with 35 DINSE Style connector. The 35 DINSE connector must be reused from the original torch, or a new one must be purchased in addition to this torch. New connectors are located under the parts category. Consumables should be changed to fit the Amperage. Can be fitted with consumables ranging from 20-80A in capacity. This type of torch uses the consumable shoulder to initiate the arc by "blowing back" the spring loaded consumable with air pressure during start to strike an arc. (This is the standard type start for most modern plasma cuttings systems under 150A.)
Torch Amperage Rating
70 Amps
Torch Connector Type
Threaded Connector
Cooling Type
Air-Cooled
Cable Length
15 Ft.
