PowerCool W300 (240V), view 1
PowerCool W300 (240V), view 2
SKU# PCW300-240
Water Coolers
$499.00
Water Coolers
SKU# PCW300-240
The 240V PowerCool W300 is designed for older Everlast welders equipped with the rear-mounted triangular cooler power connection (IEC 60320-1 C13). Recommended for welding applications up to 350A, it operates as a separate unit and must be placed beside the welder or on a shelf above or below it.
Standard B-type 9mm color-coded quick-connect couplings connect directly to Everlast water-cooled TIG and MIG torches without adapters. Included coolant line extensions provide additional reach for separate cooler placement, helping prevent strain on hoses and connections.
An audible and flashing alarm alerts you to restricted coolant flow caused by kinked or blocked hoses or loss of circulation. The alarm can be disabled for low-flow torches that trigger it during normal operation.
Built for long service life, the W300 features a copper-core heat exchanger, an Italian-made sealed industrial motor, and an Italian-made stainless steel pump with a bronze impeller. The motor, pump, and fan share a direct-drive shaft, eliminating belts and pulleys that can wear out or require replacement.
This unit operates on 240V only. While operating with any Dual-Voltage welder, this unit should be unplugged and removed from service while the welder is operating on 120V because the outlet in the rear of the welder provides only 120V while connected to a 120V outlet. Operating the cooler on 120V may cause damage to the cooler which is not covered under warranty.
PowerCool Water Cooler Coolant Requirements
Use only commercially manufactured coolant specifically labeled for TIG welding systems with High Frequency (HF) starting. However, if using for MIG with a push-pull gun that is water cooled, use only aluminum safe coolants. This requirement applies to Everlast PowerCool water coolers used with NOVA or other brands of water-cooled TIG torches.
The correct coolant helps protect the cooler, torch, and cables from corrosion, leaks, blockages, and premature failure. It must provide:
  1. Freeze protection and effective heat transfer.
  2. Low electrical conductivity for reliable HF starting and stable welding.
  3. Protection against algae and other buildup that can block coolant passages.
  4. Compatibility with the metals, plastics, seals, and hoses in the cooler and torch.
  5. Reliable circulation and resistance to breakdown during extended use.
  6. Clear handling and disposal instructions.
Do not use automotive antifreeze, RV antifreeze, isopropyl alcohol, homemade mixtures, or coolant labeled only for MIG or plasma systems. Similar colors or ingredients do not make these products interchangeable with TIG coolant.
Warranty Requirements
Warranty coverage for coolers, torches, cables, and related accessories requires the use of commercial coolant specifically designed for HF TIG welding systems, subject to the temporary water-use exception and previous-guidance provision below. No particular brand is required. Read the label to confirm compatibility before purchasing.
Common Questions
Can I use distilled or deionized water?
Only for testing or temporary emergency use, for a maximum of three weeks. Water alone provides no freeze protection and lacks the additives needed to control algae, corrosion, and component deterioration. It can also become more electrically conductive as contamination accumulates. Replace it with the required TIG coolant as soon as possible.
Which brand should I use?
Choose a commercial coolant clearly labeled for TIG welding systems with HF starting. Brand name, color, and price alone do not establish compatibility.
Can I dilute coolant or mix brands?
Follow the coolant manufacturer’s instructions. Most TIG coolants are premixed and should be used as supplied. Do not add water or mix brands or coolant types unless the manufacturer specifically permits it.
Is automotive antifreeze equivalent if its Safety Data Sheet lists similar ingredients?
No. A Safety Data Sheet does not establish suitability for TIG cooling systems or list every formulation detail. Do not use automotive antifreeze.
Previous Everlast Guidance
This notice supersedes all previous Everlast coolant recommendations. If you are using a different coolant based on earlier Everlast guidance, your warranty remains in effect. Completely drain that coolant, dispose of it properly, and replace it with the required TIG coolant as soon as reasonably possible.
Input Voltage
240V
Input Amps
1.1A
Recommended Maximum Output Amperage
350A
Power Plug Type
IEC 60320-1 C-13
Cooler Flow Alarm
Use With These Units
All Everlast 350A or less TIG, MIG, and Multi-Process units with 240V plug located in the rear of the welder. NOTE: This unit does not stack under the welder. It is meant for areas where a stacking cooler is not required or typically used.
Type of Coolant Permissible
TIG low conductivity or MIG coolant depending upon application.
Pump Type
Vane-Type
Pump Construction Type
Stainless housing with Bronze impeller
Pump Output
1.1 LPM after bypass
Motor Type
Sealed Industrial
Heat Exchanger (Radiator) Material Type
Copper core with Aluminum Fins
Reservoir Size
Approx. 2 Gallons
Torch Connection Type
Color Coded Quick Connect Coupler
