NOVA™ Slider Amp Control For Everlast TIG Units 12.5 Ft., view 1
NOVA™ Slider Amp Control For Everlast TIG Units 12.5 Ft., view 2
NOVA™ Slider Amp Control For Everlast TIG Units 12.5 Ft., view 3
SKU# NVA-SLR-TIG-15
Slider and Rotary Amp Controls For Everlast®
$179.00
SKU# NVA-SLR-TIG-15
  • Unit Weight: 2 lb
  • Shipping Weight: 3 lb
  • Unit Dimensions: 12 in × 12 in × 1 in
The NOVA slider is designed to work like a foot pedal would with infinite control between the start Amperage and the maximum Amperage set on the panel. The slider is a great solution for where a foot pedal isn't practical or for people who prefer having Amperage control at the finger tips.
This slider control has a slight detent lock in the off position so that amperage isn't accidentally rolled on or the arc accidentally started until ready. This fits Everlast TIGs units with digital control since 2016. This includes all models with green selector buttons instead of black rocker buttons. This includes 2016 and later PowerTIG, Typhoon, PowerPro, PowerUltra, UltraArc, and PowerArcs series with Foot Pedal Control. (On PowerArc models, this will only work on select STL or STH models with 7 pin control connectors. It will not work on ST models or models without any suffix model designation). This Amp control Slider also fits digitally controlled PowerTIG EXT series 2013 and later. If your welder has black rocker switches, this item will not work properly.
See the 7 pin connector in the image above to confirm fit.
Connector PIN Count
7 pin TIG
Cord Length
12.5 Ft.
