NOVA 18 Series Water-Cooled Rigid-Neck TIG Torch 25 Ft. 35 DINSE-Type Connector (No-Gas Thru)
SKU# NVA-18R-250-UF-35QD
- Unit Weight: 5 lb
- Shipping Weight: 7 lb
The NOVA 18 Series Air-Cooled TIG torch (3.0 Version) features a non-adjustable neck design with improved durability and flexibility of the Ultra-Flex torch cables over previous Nova 1.0 and 2.0 versions. The torch design is of a universal WP- type TIG torch design which means compatible consumables are available at almost any local welding supply store that sells TIG accessories. The sturdy fixed neck design is meant for rugged use and resists torch breakage. It is rated for 350A DC and 250A AC use at 100% duty cycle. The three line ultra-flex design maximizes portability and reduces total weight thanks to the food grade silicone based torch cables. This torch can be used at higher limits that the rating, but duty cycle will begin to fall off. With this in mind, the user should be conscious of the limits of the torch. The 35 DINSE-Type power connector measures approximately 1/2" in diameter at the connector pin and fits Everlast all Everlast PowerTIG, PowerPro, and Typhoon, Lightning and Thunder units that are rated for 200A or more with automatic gas control. It also fits later model PowerTIG 185 units, PowerPro 164Si and others. NOTE: Measure inside female diameter of the machine-side power connector to confirm fit. DINSE 25 connectors are smaller and measure approximately 3/8" inside the female connector. This is not a gas-valve torch. NOTICE: This torch is a water-cooled torch designed for use with a water-cooler. Operating this torch dry without a water cooler or without coolant circulating, for any amount of time will void the warranty. This does not include "on demand" type systems that automatically stop and start water flow when the arc is started. A 2T/4T remote torch switch included. (The switch is meant to control the remote program settings preset on the panel and does not directly control Amperage on the torch).
| AC Torch Amperage Rating | 240 Amps
| DC Torch Amperage Rating | 320 Amps
| Number of Main Cables | Three Line Water Cooled
| Cable Length | 12.5 Ft.
