Results 1 to 10 of 10
Thread: first functional welding project with 225lx
revkev6 first functional welding... 03-02-2011, 08:35 PM
Zoomie I think you should be... 03-02-2011, 09:19 PM
revkev6 I was reluctant to do it as... 03-03-2011, 03:19 PM
presure2 maybe a quick blast with a... 03-09-2011, 12:13 PM
pvitor Hello revkev6, How about... 03-14-2011, 12:04 AM
revkev6 Little update on this... 10-18-2011, 12:39 PM
Ram48 nice work I hope to get there... 03-10-2011, 05:24 PM
Wrenchtamer Yes balance is definitely an... 03-10-2011, 07:37 PM
pvitor I think it took lot of... 03-13-2011, 11:32 PM
performance Watch you puddle ends...you... 03-13-2011, 11:39 PM
    Orlando, Florida
    Hello revkev6,
    How about using some Navel Jelly on it and give it some time, I have used it on several rusted oil pans prior to repairing them and it attacked the rust very well and did not hurt the material cleaned up with some acetone and was very impressed.
    Peter
    Little update on this project. I helped my buddy get the rearend put back together and in the car but he never finished installing it!
    I'm not worried about vibrations as I've seen several of these driveshafts done (although not exactly like this one) and none have been balanced or had vibration issues. It runs perfect true, I made the tube a press fit over the splined coupler and took my time tacking, plug welding then doing the full weld. It was probably 20 degrees in my garage when I welded it, I had a heat gun on it for before and after to make sure it didn't have any temp related issues.
    Everlast Powertig 225LX
    Harbor Freight O/A rig
    60 gal air compressor
  1. First Project 225lx in stick mode.
    By stomper4x4 in forum Other Custom Fabrications
    Last Post: 03-26-2012, 03:33 PM
  2. Replies: 13
    Last Post: 03-25-2012, 05:28 PM
  3. My first Aluminum project on my 225LX
    By sw2x in forum Other Custom Fabrications
    Last Post: 03-03-2012, 11:58 PM
  4. Project #6 Dyethor Powertig 225lx Gas hose upgrade.
    By dyethor in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 02-28-2012, 04:04 PM
  5. First Welding Project - You guessed it... a welding cart
