What size collets are coming with the new WP9 flex head torch, and will they use a common gas lens from other readily available torches?
Thanks.
Thanks.
If I remember right they come with the standard sizes that our other torches come with. If not, they will interchange with any WP 9 or 29 Weldcraft series torch which cost a dollar or so each, and is available at any local welding supply store.
Mark
877-755-9353 x204
M-F 9am - 5pm EST
						Thanks Mark!
						The WP9 uses a smaller collet than our standard torches . And the gas lens is also smaller than the 17 -18 etc.
Each torch comes with 2 Ceramic nozzles and 2 electrode holders included.
Presently the U.S has some available
Cheers
Thanks Duncan,
I need to clarify both things we said. Both are right.
The WP 9 and 20 can accept the same size Tungsten electrodes...what I meant to say.
The WP 9 and 20 physical size of the collets are different than our other series...what you said.
To sum it up, if you have a supply of wp 18 size collets, then you will need to get some more to add to your inventory for the WP 20/9 series. Both series interchange with standard weldcraft and other brand torches. They all can be bought locally at a very small price.
Mark
877-755-9353 x204
M-F 9am - 5pm EST
WP17,18,26,28 Take the standard Ref# 10Nxx series
wp9, 20 take 13Nxx series.
both avalible from CK, Weldcraft, HTP etc etc.
____
Ray
support@everlastalaska.com
www.everlastalaska.com
877-755-9353 X207
						Thanks for the help guys, but really wanted to know "What size collets", (meaning in tungsten size), come with the torch.
I suppose the next question would be what sizes will the WP9 torch handle?
Thanks again!
						The WP9 is supplied with 1/16" Collets and #4 Ceramic .
Duty cycle is 60% @110amps.
If your WP9 torch should is rated at 250 amps it should be able to handle up to a 1/8" tungsten. If as stated above, they use industry standard collets, cups and lenses then you'll find the collets at most any decent welding store. You'll need a matching sized lense also.
There are some kits on eBay that are very inexpensive and shipped from China. I've never tried them. If they are made with recycled copper then it will likely have a higher percentagel of tin and will heat up more than high grade copper.
Steve
Miller 212
Everlast 250EX
Everlast PowerPlasma 60
Victor O/A
Gerald
Millermatic 251
Spectrum 300 Plasma
Everlast PowerTig 250EX
Everlast PowerCool W300
Harris / Victor OA
ProTools Air/Hydraulic Bender
