Results 1 to 7 of 7
Thread: Problem with cutting.
    Jul 2010
    In the Land of CoRn
    Default Problem with cutting.
    This is with a PP256, but specifically the cutter part.
    Neighbor brought over a shaft off of his lawn mower, and just wanted the pulley off of it.
    Another flange was in the way to get it on the press, so he wanted me to cut it.
    So I cut it in one place, it started going through it like butter, but then hit a spot it would not cut. I would move the torch to the side, and it would cut fresh metal, but not this one spot. I moved down a inch, and cut through it in no time.
    The shaft was about 3/4"
    Any ideas?
    Quote Originally Posted by Slick View Post
    Any ideas?
    Hello Slick
    i will double check with the guys but it maybe a torch problem. If this is the case i will express you new one asap.
    Oleg Gladshteyn
    Jul 2010
    In the Land of CoRn
    Oleg,
    I doubt its the torch as it cut the shaft just fine if I would move it out of this area, and it cut all the way through it just a inch down.
    I didn't know if it was something I did, or what, just seemed odd, there was just this one spot of metal that wouldn't cut.
    Although the only consumables for plasma(actually period) that I have are what came screwed to the torch, thanks to UPS.
    Any ideas?
    a plasma won't go through the rust so well, perhaps you had a large flake of rust.
    Jul 2010
    In the Land of CoRn
    No rust where I was cutting, but there was oil on the shaft that I cleaned off, but where is stopped cutting on the shaft was in the center.
    Slick,
    Unless there was a non conductive center or a shaft of grease...I can't think of any reason.
    Jul 2010
    In the Land of CoRn
    Slick,
    probably some non conductive material, thats all I can think of, the pulley ended up self destructing while pressing the shaft out anyway.
  1. Cnc cutting with everlast 60s
    By FeddFab in forum Everlast Plasma Cutters (PAC)
    Last Post: 10-24-2013, 09:51 PM
  2. Anybody cutting 1"?
    By Jake98 in forum Everlast Plasma Cutters (PAC)
    Last Post: 05-11-2012, 06:19 PM
  3. DIY dryer for plasma cutting and TIG welding. Dross cutting or TIG electrode fur
    Last Post: 03-15-2012, 01:08 PM
  4. Plasma Cutting
    By Lone Wolf in forum Multi-Process Units (TIG,Stick,Plasma/MIG,TIG,Stick Combo units)
    Last Post: 01-09-2012, 03:27 PM
  5. cutting at an angle
    By McClary in forum Everlast Plasma Cutters (PAC)
    Last Post: 12-29-2011, 01:01 PM
