Thread: Question about W300 water cooler???
  1. Default Question about W300 water cooler???
    I am replacing the torch connection fittings on my water cooler with 5/8"-18 LH threaded fittings so it will work with my other torches. when I took the cover off the water cooler I noticed that on the water supply line to the torch there is a small 1/8" water line that goes from the original fitting back into the water tank. What is that line used for? and will it hurt anything if I dont use that line on the new setup? I will post some pics when I get a chance. Thanks
    Please post the pics so we can see which line you are talking about.
    Jan 2010
    Chugiak , Alaska
    I beleve that is an air bleed / return to the tank. Keeps air bubbles to MIN.
    Probably don’t need it, but it might insure that pressure does not build up if the line is restricted. I noticed if it’s not pointed down and you take of the cap,, well you get it. The Italian pump flat moves some coolant.
    ____
    Ray
    support@everlastalaska.com
    www.everlastalaska.com
    877-755-9353 X207
    Sorry the image is so big I dont know how to scale it down. The orange tube is what I was referring to. There is a threaded outlet (I think its a #6-32)on the torch connection fitting that has a hose barb threaded into it and then the hose goes back into the top of the tank. This is on the water out (Cool water supply to torch) fitting. I can make one for my new connections I just wanted to know if it was an absolutely necessary piece and what it was used for.
  1. AC Power Requirements - 255EXT plus W300 water cooler
    By withanolive in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 01-23-2016, 07:24 PM
  2. Everlast 250EX and water cooler question...
    By Lucky in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 04-04-2015, 12:06 AM
  3. W300 water cooler
    Last Post: 12-05-2012, 12:53 AM
  4. powerpro 256 water cooler question
    Last Post: 10-28-2012, 06:28 PM
  5. Tig Cooler - PowerCool W300 Question
    By johnnyfive in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 05-03-2012, 10:29 AM
